> clicking sound from engine, 7a-fe
post Mar 10, 2006 - 4:25 PM
southwest2118
Joined Jan 13, '06
**** today i was trying to put the new injectors in w/305cc and everything
went well i turned down my safc like -15% and cranked the car let it warm
up. noticed the rpm was high like 1100 and i usually idle at like 900 so i
thought i was running rich so i turned the knob down but rpm went higher..
so put it at like 5% then then idle went to 900rpm i walked to the back of
the car and noticed liquid(fuel) coming out the tail pipe to i killed the car. tryed
again but this time at -30% it stayed at 900rpm?? so i take it for a test drive
and hear a clicking noise .it can't be heard when idling but at like 1500rpm
in gear you can hear it. i thought it was the injectors so i took them out and
Any body know whats going on or something i should check?
post Mar 10, 2006 - 6:40 PM
southwest2118
Joined Jan 13, '06
problem solved.. biggrin.gif .left this hose off.. when i split the intake mani it must of cam off. biggrin.gif biggrin.gif
thank god i thought i flooded the combustion chamber and fuel got past the rings and ****ed something up.
i'm going to try again later on today. but with the safc turned -30 all across.? hope i don't run lean need to find a dyno. i'm in sw houston this weekend.
This post has been edited by southwest2118: Mar 11, 2006 - 2:47 AM
Lo-Fi Version Time is now: May 24th, 2026 - 7:06 PM
