> squeeking power steering pump?, squeeks when i turn wheel all the way to left
post Mar 14, 2006 - 1:40 AM
eggman40
Joined Aug 17, '04
From California
I have a 3s on my st. I kept power steering on it. I used the GT pressure hose leading into the steering rack. Now today as i was pulling out of the driveway and turned the wheel all the way to the left it made a loud and annoying squeek. Fluid is completly full. Any suggestions? thanks
post Mar 14, 2006 - 1:46 AM
Hanyo
Joined Aug 16, '03
From Bay area
sounds like a loose powersteering pump belt.
post Mar 14, 2006 - 1:54 AM
eggman40
Joined Aug 17, '04
From California
QUOTE(Hanyo @ Mar 14, 2006 - 6:46 AM) [snapback]407304[/snapback]
theres a start, thanks ill go check it out
post Feb 5, 2007 - 3:54 PM
san0
Joined Aug 1, '06
From UK - Southern Central
QUOTE(eggman40 @ Mar 14, 2006 - 1:54 AM) [snapback]407306[/snapback]
Hi did you get this sorted in the end? I got a squeeky steering noise whilest turning left or right, always during the first few minutes of starting the car in the mornings, till it's warmed up. The PS fluid resevoir is full, so was it the PS belt loose?
san0.:GT-SS2:.
post Feb 5, 2007 - 4:08 PM
netrata
Joined Feb 16, '06
From Maui, Hawaii
yes it's the p/s steering drivebelt. Check the deflection and readjust to spec. (Easier term, tighten the belt a bit). biggrin.gif
post Feb 27, 2007 - 9:20 AM
cnelson
Joined Dec 11, '06
From New Jersey
i had the same thing, could even be a (Harmonic Vibartor?) i had to get that replaced because it was just f-in up all my belts.. -cnelson. smile.gif
"Drive Well...
...Drift Better"
post Feb 28, 2007 - 4:58 PM
Remy
Joined Jan 25, '06
From MN
QUOTE(netrata @ Feb 5, 2007 - 4:08 PM) [snapback]524181[/snapback]
I did this made it worse now I'm leaking PS fluid have to top it off everyday.... kindasad.gif waiting till the snow melts to get a better look at it.
Lo-Fi Version Time is now: August 26th, 2026 - 2:20 PM
