> newest addition to the stable.., hehe new project car WOOT
post Mar 27, 2006 - 8:13 AM
this weekend, the wifey and I, and my cousin joe went out to look at a 91 MR2 N/A, T-tops, 71k, with some minor issues.
the clutch wont fully disengage, and once the car is warm the idle fluctuates rapidly from 800-12-1300, back and forth.
so we drove out, (it was about 45 min from home) and checked it out.
pretty nice little car, minor rust spots on the 2 front wheelwells, no major body damage.
starts right up, no problem, cold idle holds fine.
try to put the car in gear, no go.
shut the car off, put it in 1st. start car, no problem. car does not "lurch" forward at all.
as SOON as you start to take the clutch pedal off the floor, it starts grabbing. like less than 1/4".
once its in gear, the clutch will not fully disengage to allow you to shift.
i could "slip" it outta 1st and into 2nd ect. by speed matching..
the clutch is new, so im thinking clutch pedal adjustment, or slave cylinder..any thoughts?
for the idle thing, that was a little odd...
cold start, idle holds fine, no problems.
once it warms up to temp, the rpms start fluctuating back and forth between like idle and 1200rpm or so, on about a 2 second interval.
the kid had paid 3500 for the car, drove it 40 miles, and it died. he did the clutch, t-belt, waterpump and assosiated parts, working on it once a month for the past several months (the car is stored at his parents house, 100miles from where he is).
basicly just sick of working on it at this point, so we jumped in, and my cousin joe bought it for 2K.
here are some pics.
im pretty excited about it, should be a really fun car once we get the little issues worked out with it..
post Mar 27, 2006 - 9:10 AM
95gtschick
Joined Sep 18, '04
From Manitoba, Canada
post Mar 27, 2006 - 9:14 AM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
good stuff manny
Kawi Love
post Mar 27, 2006 - 11:28 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Did the clutch have the problem before he replaced it? Maybe he screwed up the install. In any event, that is a bargain and I hope you enjoy it!
**** Photobucket
post Mar 27, 2006 - 11:48 AM
thats awesome manny ... i know thats your dream car.
so is it yours or your cusins?
my and my buddy had this same problem with a DSM. in his case, the clutch springs were bad. if this kid just installed it on his own... he might have put the clutch in backwards or messed up the install in another way.
but yeah, check the pedal adjustment 1st.... then see if the hydraulic cyl is moving or leaking when you press the clutch.
as for that idle problem ... try to swap out the idle AIC from another 5sfe. they tend to go bad, so that might be the problem.
ps... maybe swap the 5sfTe into it? smile.gif or better yet, your 3s!
This post has been edited by lagos: Mar 27, 2006 - 11:49 AM
post Mar 27, 2006 - 12:04 PM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
you should check the (dunno how the hell this thing is called - the thing what moves ones you puch the clutch pedal and is pulled by the main clutch bearing and etc etc LOL biggrin.gif Im a noob ) I just had the same damn thing with my WRX, had to remove gearbox 2 times just to find out what disk springs (metal plates what are on this thing) where cracked and it wount fully relise the clutch disk..
About the Idle - Vacums for sure.
And by the way - damn nice project car lol I have one of these - only thing what it is standing in my yeard for over a year now not driven lol i use it as a test bunny for all the new stuff biggrin.gif
<<<<<< DCw / JDMart >>>>>>>
post Mar 27, 2006 - 1:49 PM
95CelicaST
Joined Feb 5, '05
the thing what moves ones you puch the clutch pedal and is pulled by the main clutch bearing and etc etc LOL Im a noob )
throwout bearing?
**** Photobucket
post Mar 27, 2006 - 2:01 PM
bojangles_8686
Joined Nov 12, '02
From Baltimore, MD
That thing has 3sgte written all over it biggrin.gif Nice find and good luck!
post Mar 27, 2006 - 2:41 PM
art, the car is my cousins.
slave cylinder is not leaking at all.
we're gonna pick it up prolly later this week, once we get it to the house it will just be a matter of time!
post Mar 27, 2006 - 6:50 PM
celicurr
Joined Jan 29, '06
From Kitchener, ON, CA
wow! good deal on it!
post Mar 28, 2006 - 12:59 AM
doGGy
Joined Oct 28, '02
I remember i remember !!!! LOL Pressure plate god damn!! Check this thing up, cuz if this guy changed Clustch disk - and forgot (or was cheap out) and left the old Pressure plate - then its a posible what clutch wount separate.
post Mar 28, 2006 - 8:02 AM
nope doggmister, dude told me he had the flywheel resurfaced, with the proper .20 step in it.
the 12 second classic bettle in his garage that he built made me want to believe him..lol
the guy had like 5 cars in the driveway...his brother has a mr2T that you can see in the background of one of my pics, and his daily driver is a WRX..
im not worried about it, in a worse case, we'll drop the motor/tranny out, and get a new OEM clutch setup, and go thru things again making sure all the work he did is up to snuff, and start over.
anyone have a mr2T rear clip cheap??
HEHEHEHEHE
post Mar 28, 2006 - 8:13 AM
97lestyousay
Joined Jul 7, '03
Nice Find.
I had simalar symtoms on my old fiero.
Which ended up being a broken spring
retainer where the spring actually came
out and wedged itself to where the pressure
plate wouldn't work right.
Edit:I forgot you said u could start it with no forward movement
Mine would not engage at all.
This post has been edited by 97lestyousay: Mar 28, 2006 - 3:10 PM
JDM guy made me do it.
post Mar 28, 2006 - 8:36 AM
celicaST
Joined Jun 23, '05
thats a steal for 2k even with the problems. the clutch problem the way you explained it i would agree try to adjust the clutch pedal as you said. sounds like it engages strong but its just difficult to disengage confused.gif as for idle problem, i believe cheesylobster had a similar problem with fluctuating rpms so might want to ask him if he ever figured out what that was.
This post has been edited by celicaST: Mar 28, 2006 - 8:37 AM
post Mar 28, 2006 - 7:05 PM
kenjamatic
Joined May 20, '05
From sacramento, ca
good find i've always wanted to get one...i seem to have the same prob with the clutch also...when the engine is off you can put it in any gear but when the engine is on you have to sorta force it into gear...when in gear it'll slowly move forward/backwards(when your holding the clutch) and when your moving let say 30mph in 2nd gear and i hit the clutch the rpm doesn't drop...i bought a clutch kit from clutch city and i'm changing my clutch and axels tomorrow so hopefully that'll solve the prob...
post Mar 29, 2006 - 12:48 AM
boosted_K2
Joined Aug 30, '02
From Michigan
manny, you know this means you are going to have to get some kumho slicks so we can run against eachother sometime somewhere this season wink.gif
No but I don't buy it
Cause I'm...
Lo-Fi Version Time is now: August 30th, 2026 - 10:15 PM
