Apr 7, 2006 - 8:59 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Feb 8, '06 From Nova Scotia, Canada Currently Offline Reputation: 1 (100%) |
how much play (or slack) should there be in the throttle cable on a 5sfe? mine seems to be loose and sloppy and ì'm wondering if it could be at the origin of a low/sluggish idle. how much vertical deflection (play) should there be in a NORMAL cable? and of course how the heck am i going to adjust it if it is too loose?
Apr 7, 2006 - 9:28 AM
theres a little bracket right on the side of the intake manifold pointing to the front of the car.
its got 2 14mm bolts you loosen the appropriate one, and tighten/loosen the cable. it should have very little play, but not be pulling the throttle plate open. -------------------- Former Team 5SFTE pro member ;)
| Lo-Fi Version | Time is now: August 25th, 2026 - 9:49 PM |
