Apr 13, 2006 - 3:20 AM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 9, '05 From green springs ohio Currently Offline Reputation: 1 (100%) |
here is some pics of my turbo pics
Apr 13, 2006 - 8:13 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Dec 16, '02 From Cincinnati, Ohio Currently Offline Reputation: 0 (0%) |
Looking good How close is the turbo to the radiator?
Apr 13, 2006 - 1:49 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 29, '04 From Brooklyn moved to Miramar Florida Currently Offline Reputation: 2 (100%) |
WHAT kind of fan are you useing...
Apr 13, 2006 - 3:16 PM
QUOTE(Jeremy1210 @ Apr 13, 2006 - 8:13 AM) [snapback]420980[/snapback] Looking good How close is the turbo to the radiator? about 3 mm from the radiator to take care of the heat i am using turbo wrap QUOTE(Punch @ Apr 13, 2006 - 1:49 PM) [snapback]421115[/snapback] WHAT kind of fan are you useing... i am not sure what brand but i went to autozone and got the highest cfm i could find that would fit, and i mounted to the front -------------------- ![]() |
Apr 13, 2006 - 3:25 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 13, '05 From Poughkeepsie, NY Currently Offline Reputation: 2 (100%) |
your intercooler is in your fender? (profile pics) Care to explain that one? ( i dont know a ton, so im actually fairly intrigued by this move)
-------------------- ![]() Kawi Love |
Apr 13, 2006 - 4:20 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) |
QUOTE(devilsden97 @ Apr 13, 2006 - 1:25 PM) [snapback]421146[/snapback] your intercooler is in your fender? (profile pics) Care to explain that one? ( i dont know a ton, so im actually fairly intrigued by this move) unless its a WA SMIC, you probably want the fmic. probably should look for a slimmer radiator though; id expect trouble with that in the future... looks clean though, good job! edit: also in your profile pics, your rad hose resting on the turbo scares me... should probably move that too. This post has been edited by CheesyLobster: Apr 13, 2006 - 4:23 PM |
Apr 13, 2006 - 7:59 PM
QUOTE(CheesyLobster @ Apr 13, 2006 - 5:20 PM) [snapback]421160[/snapback] QUOTE(devilsden97 @ Apr 13, 2006 - 1:25 PM) [snapback]421146[/snapback] your intercooler is in your fender? (profile pics) Care to explain that one? ( i dont know a ton, so im actually fairly intrigued by this move) unless its a WA SMIC, you probably want the fmic. probably should look for a slimmer radiator though; id expect trouble with that in the future... looks clean though, good job! edit: also in your profile pics, your rad hose resting on the turbo scares me... should probably move that too. thanks for the explaination of the SMIC...didnt even know they made those. -------------------- ![]() Kawi Love |
Apr 13, 2006 - 9:07 PM
Enthusiast ![]() ![]() ![]() Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) |
QUOTE(devilsden97 @ Apr 13, 2006 - 5:59 PM) [snapback]421259[/snapback] thanks for the explaination of the SMIC...didnt even know they made those. TT Supras, TT 300ZX's, all turbo Eclipses, Nissan Silvias, VW/Audi 1.8T vehicles and many other cars came with stock side mounted intercoolers... Take a look through the hole under the passenger fog light in a newer 1.8T Jetta and you can see for yourself (most of the other cars have been modified so much by now that you wouldn't see them...). -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
Apr 13, 2006 - 10:27 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 10, '05 From Monroe, WA Currently Offline Reputation: 6 (100%) |
beauitiful car man! t3-60 right? hows it pull and at what psi do you run at?
oh and the SMIC almost looks like a DSM/Mitsu side mount am i right? If so, those things hold their own especially for that setup. the VR4 guys are using twin DSM intercoolers from 1G as an upgrade or for the SL 3000gt to be turboed they use them as well. much higher flow than a little 7a needs. -------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
Apr 14, 2006 - 2:40 AM
thanks guys
i want to see if i can get this little 1.8l to hang with the honda b16 turbo that my wife has -------------------- ![]() |
Apr 14, 2006 - 5:50 AM
QUOTE(phattyduck @ Apr 13, 2006 - 10:07 PM) [snapback]421290[/snapback] QUOTE(devilsden97 @ Apr 13, 2006 - 5:59 PM) [snapback]421259[/snapback] thanks for the explaination of the SMIC...didnt even know they made those. TT Supras, TT 300ZX's, all turbo Eclipses, Nissan Silvias, VW/Audi 1.8T vehicles and many other cars came with stock side mounted intercoolers... Take a look through the hole under the passenger fog light in a newer 1.8T Jetta and you can see for yourself (most of the other cars have been modified so much by now that you wouldn't see them...). -Charlie they also have some form of ducting to force air over them, so that they cool, and most owners of any of these vehicles will tell you thats one of the FIRST upgrades they make, is to a FMIC. TRD, get some cool air over that IC, or your soon gonna be picking up peices of your pistons off the road. -------------------- Former Team 5SFTE pro member ;)
Apr 14, 2006 - 5:11 PM
QUOTE(presure2 @ Apr 14, 2006 - 3:50 AM) [snapback]421443[/snapback] they also have some form of ducting to force air over them, so that they cool, and most owners of any of these vehicles will tell you thats one of the FIRST upgrades they make, is to a FMIC. TRD, get some cool air over that IC, or your soon gonna be picking up peices of your pistons off the road. Lol... yes, airflow is at least as important as size/effeciency of the core. If the air can go around it, it will - and they you loose all your cooling. I was responding to the poster who didn't even know that side mount intercoolers existed. They are a great way to package small intercoolers on stock cars. -Charlie -------------------- 2003 Subaru WRX Wagon
Apr 14, 2006 - 5:28 PM
QUOTE(trd94 @ Apr 14, 2006 - 12:40 AM) [snapback]421435[/snapback] the radiator i am having a custom one made and i removed the tranny cooling lines and had a tranny cooler put in along with a oil cooler in the other fender, i am also getting costom bent polished radiator hoses so i dont have any problem here is an older pic of my set up on my 7agte my oil cooler is mounted in the passager side which with the invader front the air flow is perfect then goes to my remote filter i have a custom made hard line for the upper rad house as for the rad i would just go with a KOYO one they fit already and you would have to change hoses but your doing that anyways ![]()
This post has been edited by nik: Apr 14, 2006 - 5:32 PM -------------------- yea your 3sgte is cool but ill stick to my 7agte
Apr 14, 2006 - 7:48 PM
for one i will tell you i have a SMIC heat soak is a gremlin that plagues us...a good FMIC is the way to go......or dual side mounts
Apr 15, 2006 - 12:40 AM
QUOTE(presure2 @ Apr 14, 2006 - 5:50 AM) [snapback]421443[/snapback] QUOTE(phattyduck @ Apr 13, 2006 - 10:07 PM) [snapback]421290[/snapback] QUOTE(devilsden97 @ Apr 13, 2006 - 5:59 PM) [snapback]421259[/snapback] thanks for the explaination of the SMIC...didnt even know they made those. TT Supras, TT 300ZX's, all turbo Eclipses, Nissan Silvias, VW/Audi 1.8T vehicles and many other cars came with stock side mounted intercoolers... Take a look through the hole under the passenger fog light in a newer 1.8T Jetta and you can see for yourself (most of the other cars have been modified so much by now that you wouldn't see them...). -Charlie they also have some form of ducting to force air over them, so that they cool, and most owners of any of these vehicles will tell you thats one of the FIRST upgrades they make, is to a FMIC. TRD, get some cool air over that IC, or your soon gonna be picking up peices of your pistons off the road. i think the smic will work ok for me like nik said the veilside kit let good air flow in also i have the z3 fenders that let air by and i modified a eclipse inner wheel fender so i have the vents to let air go out -------------------- ![]() |
Apr 15, 2006 - 12:45 AM
QUOTE(nik @ Apr 14, 2006 - 5:28 PM) [snapback]421640[/snapback] QUOTE(trd94 @ Apr 14, 2006 - 12:40 AM) [snapback]421435[/snapback] the radiator i am having a custom one made and i removed the tranny cooling lines and had a tranny cooler put in along with a oil cooler in the other fender, i am also getting costom bent polished radiator hoses so i dont have any problem here is an older pic of my set up on my 7agte my oil cooler is mounted in the passager side which with the invader front the air flow is perfect then goes to my remote filter i have a custom made hard line for the upper rad house as for the rad i would just go with a KOYO one they fit already and you would have to change hoses but your doing that anyways ![]() ![]() nik i think your car is awesome , the koyo rad is it any smaller than the stock rad ?and is any one using the greddy ultimate piggy back i think i might be looking at this to help control things a little better -------------------- ![]() |
Apr 17, 2006 - 10:37 PM
Enthusiast Joined Apr 17, '06 From Peoria, Az Currently Offline Reputation: 0 (0%) |
How is the car feeling since the install, you said it felt like it had a lot left in it? Did you end up getting all the extra parts for the system? BOV, Timer...
thx -nick -------------------- Nick
-95 st -05 xterra -07 ms3 |
Apr 18, 2006 - 5:42 PM
QUOTE(veritas @ Apr 17, 2006 - 8:37 PM) [snapback]422764[/snapback] How is the car feeling since the install, you said it felt like it had a lot left in it? Did you end up getting all the extra parts for the system? BOV, Timer... thx -nick Hehehe... just be careful (to the original poster)... turbo motors always feel their strongest right before they blow. -Charlie -------------------- 2003 Subaru WRX Wagon
Apr 18, 2006 - 10:17 PM
that is what i hear so i have been babying it till i get to the dyno and have a pro tune it better than i
Apr 23, 2006 - 9:07 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From San Juan, PR Currently Offline Reputation: 4 (100%) |
Just by getting a bit of air on the SMIC is not enough. You need direct air to flow right through it, so there is heat exchange. Just by a bit of air blowing it it's not going to cool the charge air down.
| Lo-Fi Version | Time is now: July 29th, 2026 - 6:48 AM |
