> removing lens on foglight assembly, need a how to
post Apr 13, 2006 - 9:14 AM
axelrduvirage
Joined Feb 8, '06
From Nova Scotia, Canada
1- i can't find anything in a sticky or search (my search button is worn out).
2- read something on how to remove lens from side markers once. does it apply here? (bake at 180 degrees for 8 minutes)
3- i need to clean/polish inside of lens. any tips
4- i would replace them but my local dealer wants 242$CDN each for them.WTF!
thank you
post Apr 13, 2006 - 8:28 PM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
If it's the oem fogs it is simple.... Put a pan of water of the stove... let it boil... submerge for 5 mins or so and pry off.... easy as pie smile.gif and very efective.... just dont leave it off too long or the glue will dry..... in that case you would need a heat gun or something to heat up the glue....
post Apr 16, 2006 - 9:15 AM
jdg371
Joined Jun 14, '05
same process for most fog? I have a 5GC fogs and the bulb is broken off and stuck there
post Apr 16, 2006 - 6:23 PM
JFrost9
Joined Aug 27, '05
From Texas
are 5th and 6th gens the same? They look almost identical.
post Apr 17, 2006 - 10:35 AM
dustin15brown
Joined Aug 17, '03
well it should be the samee if the 5th gen has glass lenses on the foglights.....
Lo-Fi Version Time is now: August 21st, 2026 - 2:39 PM
