> Broken tool
post Apr 22, 2006 - 2:27 PM
bigal004321
Joined Jun 21, '05
From New york
Did you guys break alot of tools while working on your swap? Cuz i just broke a craftsman adapter, with a 19mm socket attached to it trying to free the crossmember of my car! I jsut bought it ten minutes prior! Can never trust any tools i guess kindasad.gif ...it was like a $10.00 adapter too..they better replace it.
Bigal
I also broke three ratchets trying to free this same bolt...now i am using a breaker bar on it..show him whos boss!! wink.gif
1994 celica GT.....3sgte in a month! all helpers are welcome!!! i live in Plattsburgh, NY.
post Apr 22, 2006 - 2:47 PM
ZacMan1987
Joined Jan 6, '06
Liquid wrench my friend. Liquid wrench.
post Apr 22, 2006 - 3:03 PM
the problem is that you are using an adaptor. you should be using 1/2in wrench and stockets on bolts that big.
post Apr 22, 2006 - 3:14 PM
blu94gt
Joined Mar 23, '05
From Kansas City
QUOTE(lagos @ Apr 22, 2006 - 3:03 PM) [snapback]424871[/snapback]
ditto
1999 Celica GT
post Apr 22, 2006 - 3:42 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
i dont even think i removed my crossmember during my swap, but we did break 3 different ratchets a torque wrench and an actual breaker bar wrench on my axel nut.
post Apr 23, 2006 - 12:39 AM
bigal004321
Joined Jun 21, '05
From New york
Well we are bringing the engine out through the bottom of the car,,,so we have to remove the crossmember.
Bigal
post Apr 23, 2006 - 1:16 AM
morbiddelusions
Joined Mar 19, '06
From augusta ga
QUOTE(brianforster @ Apr 22, 2006 - 3:42 PM) [snapback]424885[/snapback]
I havn't tried a torque wrench but have broke my 1/2 in drive ratchet and 2 breaker bars as well
trying to do the same thing what did you use to finally get it loose cause i haven't got mine loose?
94 st
post Apr 23, 2006 - 9:57 AM
Clipsetuner
Joined Sep 12, '03
From Portland , Oregon , United States
craftsman? they suck, but I still buy them because at Sears the replace sockets, wrench's etc.. for free, if you manage to break them.. happens often enough.
DTE
I am a thief.
do not buy anything from me.
post Apr 23, 2006 - 10:53 AM
BLINKYxMUNKEY
Joined Nov 12, '03
From Crestview, Florida
I break alot of tools, espacially working at Discount Tires. I even accidently broke a broom too. kindasad.gif
FlickR
post Apr 23, 2006 - 11:01 AM
the right tool for the right job goes a LONG way towards making things easier.
for axle nuts you really need an impact, mine are on at 160Lb/ft and had been for 13 years of chicago winter. my cheapo $50 impact zapped them off like it was nothing. same for the strut to knuckle bolts at 203Lb/ft.
post Apr 24, 2006 - 8:36 AM
maxpower_hd
Joined Apr 20, '06
From Northeast Massachusetts
I did the exact same thing on the motor job on my truck. All I had in a 19mm was a 3/8 drive so I put an adapter on my breaker bar and a pipe on that and SNAP! Craftsman did replace it. I also broke a 3/8 drive ratchet which was also replaced.
I ended up buying a 1/2" drive socket and I had no more issues. My breaker bar is a Snap-On.
You should never use your torque wrenck as a breaker bar. It's for tourquing only. Like Zacman and Bitter said, Liquid Wrench and the right tool for the right job makes all the difference.
"Alcohol. The cause and solution to all of life's problems." -Homer Simpson
Lo-Fi Version Time is now: June 23rd, 2026 - 4:11 AM
