Apr 22, 2006 - 10:40 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) |
so i was driving the other day and one of the hoseclamps for my IC piping came off. Right now I don't have the tools or time really to get under the car and fix it. So pretty much my turbo is just pushing out air but its not going anywhere, and i put on a shortram intake so that i wouldn't get unfiltered air.
Is there any harm being done to my car? I plan on fixing it eventually, and i have a 2 hour drive planned for this weekend. i don't think that this would be harmful, its just like the car is being naturally aspirated for a little while. but what do you guys think? This post has been edited by CheesyLobster: Apr 22, 2006 - 10:41 PM |
Apr 22, 2006 - 11:06 PM
just fix it
you cant use those hardware store clamps. you need to buy some quality T-bolt clamps. those will never come loose on you. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Apr 23, 2006 - 12:33 AM
QUOTE(lagos @ Apr 22, 2006 - 9:06 PM) [snapback]425003[/snapback] just fix it you cant use those hardware store clamps. you need to buy some quality T-bolt clamps. those will never come loose on you. The thing is i think the reason it came off is because the pipe is cut a little too short to reach the connector easily, so it has to be streached. So for me to really fix it, id have to get a new pipe and cut it to the right size, which i can't really do living in a dorm. if i didn't just fix it do you think it would be harmful? |
Apr 24, 2006 - 6:41 PM
Enthusiast ![]() ![]() ![]() Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) |
QUOTE(CheesyLobster @ Apr 22, 2006 - 10:33 PM) [snapback]425027[/snapback] The thing is i think the reason it came off is because the pipe is cut a little too short to reach the connector easily, so it has to be streached. So for me to really fix it, id have to get a new pipe and cut it to the right size, which i can't really do living in a dorm. if i didn't just fix it do you think it would be harmful? Get a longer silicone hose and good hose clamps. It is quite harmful for a turbo to free spin (not push air against a load). It can over speed and damage the turbo. At the very least, make sure you wastegate is held fully open... -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
| Lo-Fi Version | Time is now: August 11th, 2026 - 5:57 PM |
