> timing advance
post Jun 5, 2003 - 4:36 PM
seth042280
Joined Mar 31, '03
From cary . north carolina
how do I advance my timing.
post Jun 5, 2003 - 4:44 PM
ghostdog
From ny to philly
QUOTE (seth042280 @ Jun 5, 2003 - 1:50 PM)
loosen the distributor and rotate clockwise. its strongly recommended you use a timing light though, just so you don't advance so far you enduce ping.
post Jun 5, 2003 - 4:57 PM
seth042280
Joined Mar 31, '03
hey doggy I havent had a chance to look but where is the distibutor location on st ?
post Jun 6, 2003 - 6:28 AM
edo17982
Joined Dec 21, '02
From Italy
look at the engine, it is on the right, where the plug wires are linked to.
There are 2 bolts under the distributor that u must loose.
After that rotate the distributor and tight the bolts and u're done! wink.gif wink.gif wink.gif
post Jun 7, 2003 - 10:53 AM
TRDDawg
Joined May 23, '03
From Illinois
If you advance the timing do you have to use higher octane fuel?
post Jun 7, 2003 - 11:59 AM
ghostdog
From ny to philly
QUOTE (TRDDawg @ Jun 7, 2003 - 8:07 AM)
depending on how far you advance. you should be okay up to 14 degrees. personally I would run high octane over 12 but mb thats just me, don't want to get ping ya know.
post Jun 7, 2003 - 7:48 PM
Junior
Joined May 5, '03
From Toronto
When you rotate your distributor, I believe you rotate to the right. I would definately use higher octane. After I advanced my timing, I ran regular and is ran like **** and my engine started to knock. After I put in higher octance, the car ran better.
post Jun 8, 2003 - 9:24 PM
TRDDawg
Joined May 23, '03
From Illinois
don't u have to use higher octance gas if you advance the timing?
Lo-Fi Version Time is now: August 28th, 2026 - 4:07 AM
