Apr 29, 2006 - 3:36 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
Does anyone know how to adjust the clutch? My clutch is sliping, its a brand new spec 1 with about 900 miles on it and it is slipping..
Apr 29, 2006 - 3:55 PM
![]() Enthusiast ![]() ![]() ![]() Joined Mar 17, '05 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
QUOTE(Rjb23 @ Apr 29, 2006 - 3:36 PM) [snapback]427921[/snapback] Does anyone know how to adjust the clutch? My clutch is sliping, its a brand new spec 1 with about 900 miles on it and it is slipping.. Short of pulling it out, nothing you can do TBH. Have to question why it is slipping though after such a short time? Possibility of contamination on the mating surfaces such as oil perhaps? Assume that you had the flywheel skimmed when you installed the new clutch and it was still within factory tolerances? Gary -------------------- ![]() 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Apr 30, 2006 - 11:26 AM
Yea they flywheel was turned and everything was good. I there isn't any oil leaks I checked for that. It is like it isn't releasing all the way.
Apr 30, 2006 - 12:11 PM
you prolly need to adjust the push rod.
follow the adjustmet procedure in the BGB -------------------- Former Team 5SFTE pro member ;)
Apr 30, 2006 - 2:29 PM
QUOTE(Rjb23 @ Apr 30, 2006 - 11:26 AM) [snapback]428179[/snapback] It is like it isn't releasing all the way. Bit different from your first post. As above, hydraulic system probably needs adjusting. Failing that, you may need to look at whether you need a new slave cylinder and I'd also recommend flushing out the old fluid and replacing with new. Gary -------------------- ![]() 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Apr 30, 2006 - 3:13 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 10, '05 From Monroe, WA Currently Offline Reputation: 6 (100%) |
flush/bleed the hydraulics and if that doesnt fix it, adjust the rod on teh clutch pedal, if that doesnt fix it start to suspect the slave cylinder.
-------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
| Lo-Fi Version | Time is now: August 31st, 2026 - 4:25 AM |
