> quite a few electronic accessories do not work, but its not a fuse :frown:
post May 6, 2006 - 6:53 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
ok so the following things do not turn on/work in my car:
passenger window (drivers side window works, and passenger door lock/power mirror works)
radio
clock
dome light
door ajar buzzer
probably other things i havent found out about yet
its not a fuse, i checked, im afraid i might have really fudged something up..
i accidentally put the battery cables on backward and blew the main fuse, replaced that and everything else works, so im afraid i screwed something up because when dan was here helping me put in my airbags/new dash/power windows he tested all that stuff and it worked..
any ideas guys?
post May 6, 2006 - 10:38 PM
if it isn't any fuse (in the bay and the interior) you might of blown the voltage regulator in the alternator.
post May 6, 2006 - 11:41 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
Check the plugs behind the door panel. You might have forgot to plug something back in. Also double check the three interior plugs next to the ECU
I will return one day.
post May 7, 2006 - 5:10 AM
brianforster
Joined Mar 3, '04
From Hollywood, MD
if my alternator was messed up wouldnt i have a battery light?
im pretty sure all the plugs are in because they worked at one point, thats what scares me the most frown.gif
This post has been edited by brianforster: May 7, 2006 - 5:11 AM
post May 7, 2006 - 8:56 AM
bojangles_8686
Joined Nov 12, '02
From Baltimore, MD
QUOTE(defgeph @ May 6, 2006 - 11:41 PM) [snapback]430987[/snapback]
Are you talking about the 3 on that metal bracket? If so, I remember plugging those in yesterday. Nothing changed.
This post has been edited by bojangles_8686: May 7, 2006 - 8:56 AM
post May 7, 2006 - 10:49 AM
brianforster
Joined Mar 3, '04
From Hollywood, MD
it ended up being an engine bay fuse that was labeled as X but was blown, replaced it and everything works now except the passenger window and the horn, i found the horn wasnt hooked up up front , but it wasnt long enough (is the horn in a diff spot on an st vs a gt?) so i extended the plug and it doesnt work still, but the horn relay in the engine bay clicks every time i press the horn down
anyone have any idea why my pass window isnt working and now the horn?
post May 7, 2006 - 11:12 AM
you cant be "pretty sure" when working with electrical stuff. you have to go back and check ten times. a lot of times you just forget to plug something back in and it causes a lot of strange issues.
post May 7, 2006 - 11:30 AM
brianforster
Joined Mar 3, '04
From Hollywood, MD
Lo-Fi Version Time is now: August 22nd, 2026 - 11:30 PM
