May 16, 2006 - 6:45 PM
Enthusiast ![]() ![]() Joined Apr 4, '06 From Minnesota Currently Offline Reputation: -1 (0%) |
there are so many bolts surrounding the valve cover that i dont know where to unscrew from. i dont want to make a mistake and then forget where they go (sorry i have a short memory). how many bolts and where are they located? thanks
May 16, 2006 - 7:05 PM
Enthusiast ![]() ![]() Joined Oct 10, '05 From San Diego Currently Offline Reputation: 2 (100%) |
you need to..
1. take the spark plug wires off of the spark plugs 2. take off the spark plug tube nuts (4) underneath the spark plug wires 3. take off the washers/ spacers underneath the spark plug tube nuts 4. take a block of wood and a hammer to jar the valve cover loose because it will be snug... or take a putty knife and pry underneath the valve cover that should do it for you |
May 16, 2006 - 8:26 PM
This post has been edited by Jaws4God: May 16, 2006 - 8:28 PM -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
May 16, 2006 - 9:25 PM
good deal. thanks a lot guys. the explanation and pictures really helped me out!
May 18, 2006 - 6:55 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) |
Does the 7A have the spark plug tube nuts? I can't see them if it does.
May 18, 2006 - 10:10 AM
Enthusiast ![]() ![]() ![]() Joined Dec 28, '05 From USA Currently Offline Reputation: 0 (0%) |
^you dont have to, just unplug the plugs (pull them off CAREFULLY! DONT YANK THEM OUT!) and set them aside, its a good idea to mark them so you dont mix them up when you put them back
May 18, 2006 - 5:12 PM
You don't need to, they're numbered 1-4 and they have different lengths for each, 1 being the longest, 4 being the shortest
May 18, 2006 - 5:51 PM
QUOTE(Cutrara @ May 18, 2006 - 6:55 AM) [snapback]435206[/snapback] Does the 7A have the spark plug tube nuts? I can't see them if it does. as far as i know it doesnt, i dont see where it would :dunno: -------------------- |
May 18, 2006 - 6:59 PM
Enthusiast Joined Feb 4, '06 From washdc Currently Offline Reputation: 0 (0%) |
QUOTE(Bitter @ May 18, 2006 - 5:51 PM) [snapback]435438[/snapback] QUOTE(Cutrara @ May 18, 2006 - 6:55 AM) [snapback]435206[/snapback] Does the 7A have the spark plug tube nuts? I can't see them if it does. as far as i know it doesnt, i dont see where it would :dunno: The 7A has 4 separate nuts on the body of the valve cover - supposedly with gaskets that you need to keep associated with the proper post that you removed them from - at least that's what my Chilton's said - offering me help on this with a 7A but none for a 5sfe. -------------------- 94 CelicaGT producing massive amonts of NOx - UGH!!!
98 Volvo V70 - guzzling lots of gas - GAAH! |
| Lo-Fi Version | Time is now: September 15th, 2026 - 8:13 PM |
