May 18, 2006 - 3:31 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 17, '04 From California Currently Offline Reputation: 20 (100%) |
Hello everyone, I am getting ready to get a boost controller and put my 3sgte at 13psi and wanted to make sure i dont miss anything and hutrt the motor.
I will install a FMIC and a turbo xs boost controller. i have the stock ct26 turbo on the 2nd gen 3s. Aside from a better fuel pump what else will i need to do? Thanks for the help ahead of time This post has been edited by eggman40: May 18, 2006 - 3:44 PM |
May 18, 2006 - 3:35 PM
the stock turbo for that car is a ct26 not a ct20.
get your fmic and a walbro or supra fuel pump in the tank. other then that, turn it up and enjoy the new car. 13psi is where it all starts to come alive. -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 18, 2006 - 3:38 PM
youll also have to disable fuel cut. there are many ways to do that tho
May 18, 2006 - 3:42 PM
QUOTE(lagos @ May 18, 2006 - 8:35 PM) [snapback]435374[/snapback] the stock turbo for that car is a ct26 not a ct20. get your fmic and a walbro or supra fuel pump in the tank. other then that, turn it up and enjoy the new car. 13psi is where it all starts to come alive. Fuel cut will this work or can i find it cheaper? |
May 18, 2006 - 3:54 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) |
You can disable fuel cut by disconnecting the vacuum line to the Turbo Pressure Sensor and plugging it.
If you want to retain fuel cut you can just wire in a zener diode to the PIM input of your ECU or build this simple circuit to make it adjustable: http://toymr2.tripod.com/fcd.html EDIT: WHOA! just clicked the ebay link... DO NOT PAY $89 FOR THAT! This post has been edited by WannabeGT4: May 18, 2006 - 4:14 PM -------------------- ![]() Project ST204.5 99.88946% complete... |
May 18, 2006 - 5:31 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 4, '04 From Northern New Jersey Currently Offline Reputation: 2 (100%) |
fuel cut defenders like the hks are highly overrated. i think the lowest boost u can set the hks one to is actually 17psi if im not mistaken. theres a great how-to over at mrcontrols.com on how to make ur own fuel cut defender. i made one for myself based on that site and its fully adjustable and works like a charm. or if ur not too familiar with electronics i can make 1 for yah
edit: the link wunnabegt4 posted is the how-to im talking about...its alot more adjustable than the hks bboy This post has been edited by BBoYRuGGeD: May 18, 2006 - 5:33 PM -------------------- ![]() ..(formerly daily driven) 3S-GTE powered celica currently set @ 12psi.. |
May 18, 2006 - 5:52 PM
QUOTE(WannabeGT4 @ May 18, 2006 - 8:54 PM) [snapback]435382[/snapback] You can disable fuel cut by disconnecting the vacuum line to the Turbo Pressure Sensor and plugging it. If you want to retain fuel cut you can just wire in a zener diode to the PIM input of your ECU or build this simple circuit to make it adjustable: http://toymr2.tripod.com/fcd.html EDIT: WHOA! just clicked the ebay link... DO NOT PAY $89 FOR THAT! Thank you, that helps a lot! the mr2 instructions look complicated. Ill get back to you guys on what i had to do. thanks again i appriciate it |
May 18, 2006 - 7:38 PM
just unplug and cap the map sensor. thats what i did. free fuel cut!
i did build my own fcd based on that sites info, but never got around to installing it in my car. -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 18, 2006 - 8:21 PM
bboy.... can you take a pic of where you mounted your fcd and how it ended up looking?
May 18, 2006 - 8:45 PM
QUOTE(lagos @ May 19, 2006 - 1:21 AM) [snapback]435508[/snapback] bboy.... can you take a pic of where you mounted your fcd and how it ended up looking? sure thing bboy -------------------- ![]() ..(formerly daily driven) 3S-GTE powered celica currently set @ 12psi.. |
May 18, 2006 - 9:08 PM
![]() ![]() i used this ^ velcro to mount it. this things awesome if u wunna mount anything to a brick, metal, or plastic surface. its weather proof too and can hold heavy crap like my drill on my garage wall lol bboy -------------------- ![]() ..(formerly daily driven) 3S-GTE powered celica currently set @ 12psi.. |
May 18, 2006 - 11:06 PM
all good stuff. i was wondering how i would mount mine. velcro seems like an easy fix to that problem.
| Lo-Fi Version | Time is now: August 25th, 2026 - 12:05 AM |
