> No A/C code 51?
post May 20, 2006 - 10:26 AM
Rjb23
Joined Feb 8, '04
From KY
Hey guys I don't have my A/C hooked up and I don't get a cel, but if I have the diagnosis pins jumped when the car is running and I give it any gas I get a code 51. Which is IDL No "IDL" or A/C signal during testing Check TPS, A/C switch, Accelerator cable. I don't have my A/C hooked up or the A/C throttle up switch hooked up, will this throw that code?
post May 20, 2006 - 1:07 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
from my experience that code is thrown most often for throttle cables, TPS would throw it too but youd likely know if something was wrong with your TPS.
unhook your throttle cable from the throttle body and see if the code goes awya, im willing to bet like myself and lagos that your throttle cable is too tight or not adjusted properly.
what method of extending the throttle cable are you using? because it is a known issue that the stock throttle cable mounting position is too short and angled a little to the left.
post May 20, 2006 - 1:20 PM
QUOTE(brianforster @ May 20, 2006 - 2:07 PM) [snapback]436036[/snapback]
good to see the next generation step in and take over! smile.gif good tips, brian!
post May 20, 2006 - 6:27 PM
Rjb23
Joined Feb 8, '04
From KY
Nope the throttle cable being to tight is definatly not the problem. It is actually a little loose and there is a little slack in it. The only time I get the code is when I rev, and its doesn't even show up unless I rev the engine with the diagnostic pins jumped.
post May 20, 2006 - 6:38 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
my car does that exact same thing, i have a theory but im not 100% on it..
my theory is that when you press the gas its pulling on the throttle cable and tightening the cable and the ecu thinks that is the cable being too tight
wed need someone who has a completely functional vehicle to test this theory out though, art? jeff?
post May 20, 2006 - 7:04 PM
Rjb23
Joined Feb 8, '04
From KY
I think it has to do with my ac not being hooked up and my idle up sensor for the ac not being present.
post May 20, 2006 - 7:08 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
rj, art and i had this arguement many times and he always came back with "plenty of people without a/c do not throw code 51"
plus if that code was ANYTHING but the throttle cable it would show up when you turn the car on, not only when you press the gas.
post May 25, 2006 - 5:55 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
i think i should point out that art tested my theory today and i am correct, when you give your car gas in diagnostic mode you are going to get a code 51 because the car thinks your throttle cable is too tight (duh because when you press the gas the throttle cable tightens)
woot my first correct theory!
post May 25, 2006 - 7:08 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
Nice work. DIA mode is for idle only. I dont have AC at all AC components all removed, no codes here.
I will return one day.
post May 26, 2006 - 8:15 AM
Rjb23
Joined Feb 8, '04
From KY
Cool, that takes care of that code.
This post has been edited by Rjb23: May 26, 2006 - 8:15 AM
Lo-Fi Version Time is now: August 4th, 2026 - 9:43 AM
