> what fuel pump do I need???
post May 30, 2006 - 6:46 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
Im doing the 3sgte swap into my 95 celica gt. Im looking at walbro fuel pumps, but I cant find any 255 lph specifically for 6g celicas. Will the twin turbo supra walbro fuel pump drop right into my tank? If not how much modification is needed? Heres the walbro part #GSS341 . Also, has anyone had the walbro fp fail on them. Thanks for any advance! <Brian>
post May 30, 2006 - 7:11 PM
It requires a little "persuasion" but yeah it'll fit.
Or you can get the stock TT pump.
post May 30, 2006 - 7:38 PM
bigal004321
Joined Jun 21, '05
From New york
the walbro are tough fuel pumps though if you can stand the whining noise that they make.
Bigal
1994 celica GT.....3sgte in a month! all helpers are welcome!!! i live in Plattsburgh, NY.
post May 30, 2006 - 9:00 PM
gtfc115
Joined Aug 14, '04
From Toledo, Ohio
QUOTE(bigal004321 @ May 31, 2006 - 12:38 AM) [snapback]439512[/snapback]
Bigal
ive never been able to hear mine until recently when i took my back seats out. even then i cant hardly hear it.
post May 31, 2006 - 5:10 AM
toyotacrazy
Joined Mar 4, '06
From Ohio
Im using my fuel pump resistor with the swap. Ive heard that will help keep it quiet. Ill have to see how much I can get an oem tt supra fp for. Id rather stay oem.
post May 31, 2006 - 7:07 AM
the denso supra pump is about 200$
if you buy the foam sleeve they sell for the walboro, it basicly eliminates the whine.
post May 31, 2006 - 7:34 AM
And a Walbro's about 80 and probably just as good if not real close.
post May 31, 2006 - 8:28 AM
Kadett
Joined Mar 17, '05
From The Netherlands
I used the one that was on the ST205, no problems whatsoever with it. Install in ST202 tank was easy.
post May 31, 2006 - 8:35 AM
for refrence, heres the pump test wolfkatz did a while back.
the n/a mr2 pump is the equivlent of our stock fuel pump.
post May 31, 2006 - 8:45 AM
I dont think I need to really say this, but if you have a turbo, or you have a swap, and you havent changed your fuel pump, I hope that diagram scares you into doing it ASAP.
post May 31, 2006 - 10:14 AM
brianforster
Joined Mar 3, '04
From Hollywood, MD
you know i cant hear the whinebro at all in my car
post May 31, 2006 - 11:50 AM
jcbass7
Joined Apr 20, '06
From Florida
how about the stock mr2 turbo, fuel pump. is that one adequate? it looks decent on the graph there
actually looking at the graph again it look like a halfway decent set-up if you run the stock pump feeding into an inline walborro..
This post has been edited by jcbass7: May 31, 2006 - 11:52 AM
post May 31, 2006 - 7:49 PM
its more work to add an inline pump than it is to replace the stock one.
they do it on mr2's because you have to drop the tank to get to the pump on theyre cars.
the stock mr2/alltrac pump is good for stock boost, not much more at all.
post Jun 1, 2006 - 6:10 PM
Speedy2k
Joined Jan 6, '06
From Toronto, Canada
Actually the stock 3sgte pump is good up to ~ 275rwhp. Which is definatley not stock.
post Jun 1, 2006 - 6:57 PM
QUOTE(Speedy2k @ Jun 1, 2006 - 7:10 PM) [snapback]440203[/snapback]
post Jun 1, 2006 - 8:10 PM
jcbass7
Joined Apr 20, '06
From Florida
so what would be a smart choice in a 3sgte swap situation? I'm talking about a direct replacement for the pump in the tank now. does walborro make a pump that goes in there and isn't the inline one? i know the supra pump isn't a bad choice
PS: im an idiot, just re-read first post........ so maybe the walbro supra pump with "persuasion" would be a decent choice?
This post has been edited by jcbass7: Jun 1, 2006 - 8:11 PM
post Jun 4, 2006 - 9:19 PM
Speedy2k
Joined Jan 6, '06
QUOTE(presure2 @ Jun 1, 2006 - 6:57 PM) [snapback]440210[/snapback]
RickyB said it himself that below 300rwhp you should be alright on the stock fuel pump. 275 to be safe...
post Jun 5, 2006 - 7:26 AM
QUOTE(Speedy2k @ Jun 4, 2006 - 10:19 PM) [snapback]441066[/snapback]
yup...your right...i was thinking the n/a pump.
although i cant see spending the extra 100$ on the turbo pump, when the walboro does the job better, for under 100$.
jc, heres a pic of the walboro installed in the 5s holder.
post Jun 5, 2006 - 12:24 PM
here is a better one
post Jun 5, 2006 - 12:34 PM
QUOTE(brianforster @ May 31, 2006 - 11:14 AM) [snapback]439716[/snapback]
wait till you get your exhaust done..lol
i LOVE my OEM supra pump. its well worth the money not to have to listen to that damn whine.... EEEEEEEEEEEEeeeeeEEEEeeeeeeeeeeeeeeeee
This post has been edited by lagos: Jun 5, 2006 - 12:34 PM
Lo-Fi Version Time is now: September 12th, 2026 - 11:17 AM
