> ignitions, 3s or 5s
post May 30, 2006 - 7:41 PM
bigal004321
Joined Jun 21, '05
From New york
If i am doing a 3sgte swap into my celica GT which ignition should i use...the 5sfe or the 3s?
Bigal
PS i would assume that i would use my stock one and just wire it to work with the 3s, but i am uncertain.
1994 celica GT.....3sgte in a month! all helpers are welcome!!! i live in Plattsburgh, NY.
post May 30, 2006 - 8:01 PM
Are you talking about ignitor or ignition coil or what here?
You use 3sgte stuff.
post May 30, 2006 - 8:24 PM
bigal004321
Joined Jun 21, '05
From New york
I am talking about what i put the key into and turn to start my car..is it the 3sgte one i took from my clip or do i use the one already in my celica.
Bigal
post May 30, 2006 - 9:20 PM
Oh, dont touch it.
post May 31, 2006 - 4:38 PM
phattyduck
Joined Dec 5, '05
From LA, CA
Generally, when you say "ignition" in this forum, people will assume you are talking about the components in the engine bay (ignitor, plugs, wires, etc.).
You should use your original wiring to the starter, and the wiring that goes around the car for the starting signal (STA pin on your ECU) should also be original from your car and simply spliced into new harness near the ECU. You can keep your current circuit opening relay or wire in the one from the clip, either one will work if you do it correctly.
Wiring that is more related to your car should stay, wiring that is more related to the motor should be from the clip. Just use some common sense and you'll get through it...
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post May 31, 2006 - 8:26 PM
bigal004321
Joined Jun 21, '05
From New york
thanks for the help!
Bigal
Lo-Fi Version Time is now: September 7th, 2026 - 7:04 PM
