Jun 21, 2006 - 7:18 PM
i KNOW i had all 4 of my plugs at .8MM about 6 months ago. i regapped them the other day and 3 were at .65-.75MM with one still at .8MM. is this within normal bounds or is something awry? i can tell when the gaps are getting out of whack, i get slight misfires at an unloaded idle.
the plugs read as my combustion temp being a little high but not out of a 'normal' range. i expect this from my timing advance, but this slowy shrinking gap has me a little concerned. -------------------- |
Jun 21, 2006 - 7:23 PM
what kind of plugs are these?
Jun 21, 2006 - 7:29 PM
ah i did forget that information!
plain jane Delco brand plugs, whatever stock 7afe specs are is what these plugs are. regular steel plugs with a black oxide coating, about $1 each. plugs are pretty much plugs, i got these after a bad run with bosch platinums. no one told me that the 7afe likes a wider gap on plat plugs (.044-.046 inch vs .030 inch for standard i beleive). -------------------- |
Jun 21, 2006 - 7:30 PM
get some denso or ngk and be happy
Jun 21, 2006 - 7:32 PM
QUOTE(LewFX @ Jun 21, 2006 - 7:30 PM) [snapback]447392[/snapback] get some denso or ngk and be happy and the difference between standard delco plug and a standard denso (ngk is denso btw) plug is what? while i do appreciate the response, im looking for the root of the problem. i suspect that even a set of standard denso plugs would do the same thing since theyre constructed of the same material as the delco plug. like i said, standard plugs are standard plugs. This post has been edited by Bitter: Jun 21, 2006 - 7:34 PM -------------------- |
Jun 21, 2006 - 7:36 PM
i thought irridiums are far better than standard..im too lazy to look in my manual about this, ill try a google search
Jun 21, 2006 - 7:39 PM
QUOTE(LewFX @ Jun 21, 2006 - 7:36 PM) [snapback]447396[/snapback] i thought irridiums are far better than standard..im too lazy to look in my manual about this, ill try a google search irridiym and platinum plugs just have a longer service life, in the 7afe and 1zzfe/2zzge you have to widen the gap because you get a weak spark between the points. this is because the sharp point conducts too well and the needed potential isnt reached with the stock gap. -------------------- |
Jun 22, 2006 - 4:11 PM
any other input?
| Lo-Fi Version | Time is now: May 26th, 2026 - 6:12 AM |
