> freshman installing an amp, need help please!, how to run the main power wire from the battery to the cabin?
post Jul 2, 2006 - 10:58 AM
xkillerx
Joined Jun 19, '06
From yugoslavia (or what's left of it)
hello people!
about a month ago i FINALLY became an owner of a 6th geni celica - after many years of craving for one. much of the SQ audio system i had in my ex-corolla is now waiting for an installation. i was looking today for some kind of hole i could use to put in the 10mm2 (awg 1 or 0 i guess) power wire (from the battery to the cabin) but couldnt find anything frown.gif
i'm running a 97 ST with air conditioning, abs and all the good stuff.
also i'll probably be getting new speakers for my car. bare in mind, GOOD speakers are a NIGHTMARE to buy here (and i pretty much CANT order stuff from the net). the choice comes down to three contenders: jbl gto6507c OR apline type S 171A or ground zero hydrogen 17cm components (a completely unknown yet quite expensive german brand). i believe the JBL component system should sound the best and cost the least, but i'm waiting for feedback from all you car audio enthusiasts (i know there's a whole bunch of you here! biggrin.gif ) for the speaker brand decision (and please, please dont recommend stuff i cant get. frown.gif trust me if i could i'd get polk's or mb quart's or infinity's but they are NOT an option in this $h17hole country mad.gif )
You say you love flowers but you pick them, You say you love animals but you eat them, I fear the day you'll tell me you love me.
post Jul 2, 2006 - 11:23 AM
jess_i_74
Joined Sep 19, '05
QUOTE(xkillerx @ Jul 2, 2006 - 11:58 AM) [snapback]451214[/snapback]
hello people!
If you are standing in front of the car with the hood open, facing the engine, there is a hole through the firewall from the front left corner of the hood (right behind the filler tube for the . . . brake fluid, I think, I can check if you like). This feeds through to the driver's footwell, right by the kick panel on the right side. You may have to enlarge it to run AWG 0 (heck of a wire, that is!). You will have to remove the small kick panel inside; there is a plastic nut, as well as lifting your door sill and the trim that runs by the dash. Let me know if you need pics; I can try and get them.
post Jul 2, 2006 - 11:59 AM
Nibbe
Joined Jan 6, '05
From Finland, Turku
Ground zeros are some good quality stuff for sure. Cost a bit much but sounds good too.
Please visit on our teams new website. hrp-tuning.com
19in deepdishes - invader bodykit - invader cf hood - x-box - dls audio
post Jul 2, 2006 - 12:16 PM
K-ESD
Joined May 5, '05
From New-Brunswick Canada
the cleanest and easiest way to install the wire is to run it inside the driver side fender
Take off the door sill (just pops off) and take off the driver side kick panel.
Jack the car up from the front driver side, remove wheel, pop the hood
you can find a hole next to the battery, right under fuse box. Stuff your wire in there. Take off the screws holding the mudguard to expose the inside of the fender. Pull your wire all the way, run it along the stock wire loom. On the driver side kick panel area (outside the car) you will find two grommets, one of them has a nipple on it. Cut the nipple off and stuff your wire through. You'll probably have to stretch it a lil bit for 0AWG wire. From the inside the car, pull the wire all the way.
Reassemble the mudguard, put the wheel back on and drop the car
Pull on the carpet by the door to expose a long white box that runs front to back. On the side of the box you will find clips that would normaly hold small (4AWG or smaller) wire. Cut all the clips off and run your wire along there. The carpet will hold it in place when you put it back. The rest is self explainatory. Run the wire inside the rear side panel or under the seat, etc...
----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy
post Jul 2, 2006 - 3:28 PM
xkillerx
Joined Jun 19, '06
QUOTE(jess_i_74 @ Jul 2, 2006 - 11:23 AM) [snapback]451219[/snapback]
hello people!
QUOTE(Nibbe @ Jul 2, 2006 - 11:59 AM) [snapback]451226[/snapback]
thank you for this. i'll start a new topic for the speaker debate!
K-ESD, jess, could both of you please get some photos? both of your methods make sense.. although i'm not sure i'll be able to but the mudguard back together once i take it off. looks really well bolted together that thing kindasad.gif
post Jul 3, 2006 - 9:30 PM
ShadowFX
Joined Jan 22, '04
From WA, Australia
Here's where I ran mine. (Keep in mind mine is RHD)
Made a small slit in the ribber boot circled in purple, and just fed the wire through.
I took the glovebox out to make it easier, and after feeding enough wire through, it came out here, behind the glovebox. (Following the path of the arrow). Then just ran it under the side carpet to the boot.
post Jul 7, 2006 - 11:31 PM
XS4lv1Truch0x
Joined Dec 9, '05
From Long Beach
i used the clutch hole thingy and ran the wires under the carpet.
the rca cables, you should run under the other side of the car
cause power from the 12v+ will be picked up by the rca cables and you will get some noise.
12v+= left side of car
remote turn on = left side of car
rca cables = right side of car.
Is this good enuff 4 ya? :D
post Jul 8, 2006 - 12:36 AM
Niskyspy
Joined Jan 21, '05
From NY
QUOTE(K-ESD @ Jul 2, 2006 - 12:16 PM) [snapback]451232[/snapback]
Thats what I did and yes it takes way more time and sometimes just a killa but it does make a clean install. I did it because I didn't feel like cutting through the rubber surrounds in the engine bay wink.gif
<<AKA THA RUSSIAN>>
post Jul 8, 2006 - 8:37 AM
K-ESD
Joined May 5, '05
QUOTE(Niskyspy @ Jul 8, 2006 - 2:36 AM) [snapback]453283[/snapback]
I did this procedure on rayme's celica and it took me less than 15 mins start to finish, took me a lil longer previously when i did it on mine w/ 0g wire and having to figure the whole thing out. Having the luxury of someone telling you "the right way" is priceless.
post Jul 8, 2006 - 4:49 PM
xkillerx
Joined Jun 19, '06
QUOTE(K-ESD @ Jul 8, 2006 - 8:37 AM) [snapback]453355[/snapback]
this "right way" really sounds right, but could you maybe share some photos or more tips with us? especially around the mudguard part... looks to me like i'll mess something up there for sure. also, this would be priceless for the how-to section dont you think? once i get around my car and run the wire i'll be sure to take lots of photos for future celica-newbies.
Lo-Fi Version Time is now: June 26th, 2026 - 7:45 AM
