> Turbo trubble
post Jul 11, 2006 - 9:04 AM
nate95
Joined May 5, '05
From mattoon, IL
Im haveing a problem figureing out what to do with my turbo,, the way i have to have the turbo positiond in my car the oil return is pointing up on the turbo, does it matter where the return is located? if so what can i do to solve the problem?
post Jul 11, 2006 - 9:18 AM
the oil return should ALWAYS be point straight down.
you need to clock the housing.
post Jul 11, 2006 - 9:40 AM
nate95
Joined May 5, '05
From mattoon, IL
well thats another problem, clockin the housing wont help any, becuase the oil return is connected to the housing, and the housing has to stay pointed the way it is or it wont connect to the manifold
post Jul 11, 2006 - 10:34 AM
QUOTE(nate95 @ Jul 11, 2006 - 10:40 AM) [snapback]454531[/snapback]
the CHRA will rotate seperate from the flange.
post Jul 11, 2006 - 7:58 PM
trd94
Joined Jan 9, '05
From green springs ohio
QUOTE(nate95 @ Jul 11, 2006 - 9:40 AM) [snapback]454531[/snapback]
what is this turbo out of , and like pressure said you can clock the housing, pics would help
Lo-Fi Version Time is now: August 31st, 2026 - 4:25 AM
