Jul 11, 2006 - 2:39 PM
Ok so in all my reading over on Mr2oc i've seen alot of setups and looked at a ton of different situations and options on ways to build things.
but one thing i've been confused about slightly is the shimless bucket conversion i know where it happens but i don't know why and how it happens? if someone could explain the benefits of the conversion and how its done that would be great |
Jul 11, 2006 - 2:50 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) |
By removing the shims it's supposed to be more reliable at higher revs.
Clearance measurements between the cam lobe and bucket are taken at each valve. The thickness of each shim and bucket is measured. With this information you can now order the correct shimless bucket for each vavle by comparing the total thickness of the original shims and buckets and comparing it to the clearance measurements of each cam lobe and bucket. -------------------- ![]() Project ST204.5 99.88946% complete... |
Jul 11, 2006 - 2:51 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 29, '02 From Lake Orion, MI Currently Offline Reputation: 6 (100%) |
QUOTE(WannabeGT4 @ Jul 11, 2006 - 12:50 PM) [snapback]454661[/snapback] By removing the shims it's supposed to be more reliable at higher revs. Clearance measurements between the cam lobe and bucket are taken at each valve. The thickness of each shim and bucket is measured. With this information you can now order the correct shimless bucket for each vavle by comparing the total thickness of the original shims and buckets and comparing it to the clearance measurements of each cam lobe and bucket. My engine house wanted to use all the same sized buckets and they actually lob the top of the valve off... thought that was an interesting way to do it -------------------- -Mike
mjcoury@gmail.com Team Reynolds Style Celica Blog Celica Wiki It will take him a moment to realize that he's about to make a 180 degree turn at speed, but you will be ready for it. Brace for the g's, and fast heel-toe work. |
Jul 11, 2006 - 2:56 PM
QUOTE(WannabeGT4 @ Jul 11, 2006 - 3:50 PM) [snapback]454661[/snapback] By removing the shims it's supposed to be more reliable at higher revs. Clearance measurements between the cam lobe and bucket are taken at each valve. The thickness of each shim and bucket is measured. With this information you can now order the correct shimless bucket for each vavle by comparing the total thickness of the original shims and buckets and comparing it to the clearance measurements of each cam lobe and bucket. so now is the bucket supposed to touch the lobe at all times and the goal to get the right thickness to achieve this? or is there a specified "clearance" which we would subtract from the actually distance to get the size of shimless bucket needed? |
Jul 11, 2006 - 3:06 PM
I'll have to consult the BGB.
![]() QUOTE(qatar11 @ Jul 11, 2006 - 2:51 PM) [snapback]454662[/snapback] My engine house wanted to use all the same sized buckets and they actually lob the top of the valve off... thought that was an interesting way to do it That is a rather interesting way to accomplish the same thing. Personally, I'd rather spend a little extra time measuring than machining valve stems. This post has been edited by WannabeGT4: Jul 11, 2006 - 3:17 PM -------------------- ![]() Project ST204.5 99.88946% complete... |
Jul 11, 2006 - 3:51 PM
i assum your pointing out the "valve clearance" i didn't realize that measurment was up by the bucket...ok thanks a lot really appreciate the help
Jul 11, 2006 - 4:09 PM
Your assumption would be correct.
| Lo-Fi Version | Time is now: August 31st, 2026 - 5:51 AM |
