Jul 16, 2006 - 11:20 AM
Enthusiast ![]() Joined Jan 18, '06 From St.lucia Currently Offline Reputation: 0 (0%) |
hey can anyone help me with a site that has the engine error codes for the 3sgte
Jul 16, 2006 - 12:41 PM
Jul 16, 2006 - 2:23 PM
here:
http://celicatech.com/forums/showthread.php?t=10155 3sgte CEL Error Code List 11 - ECU Momentary interrupt in power Check relays, IG switch 12 - RPM No "G" signal to ECU for 2 sec after crank Starting related, check distributor, starter 13 - RPM No "NE" signal to ECU above 1000 RPM Check distributor 14 - IGN No "IGF" signal to ECU 8-11 times Check Igniter, ignition coil 21 - O2 Detection of oxygen sensor detoriation Check oxygen sensor 21 - O2 Open or short circuit in o2 sensor heater Check oxygen sensor 22 - WTR Open or short in Water Temp Sensor Check Water Temp Sensor 24 - AIR Open or short circuit in Air Temp Sensor Check Air Temp Sensor 25 - O2 Excessive Lean Air Fuel Ratio Check o2 sensor and fuel system 26 - O2 Excessive Rich Air Fuel Ratio Check o2 sensor and fuel system 31 - AFM Open circuit or short in VC signal Test or replace Air flow Meter 32 - AFM Open circuit or short in E2 signal Test or replace Air flow Meter 34 - TRB Fuel cut due to excessive turbo pressure Check Wastegate Hose, Test Pressure Sensor 35 - TRB Open or short circuit in Pressure Sensor Test Turbo Pressure Sensor 41 - TPS Open or short circuit in VTA signal Test Throttle Position Sensor 42 - SPD No "SPD" signal over 8 seconds driving Check Vehicle Speed Sensor 43 - STA No "STA" signal over 800 RPM starting Check Ignition Switch 51 - IDL No "IDL" or A/C signal during testing Check TPS, A/C switch, Accelerator cable 52 - KNK Open or short circuit in Knock Sensor Check for broken/brittle wire, Replace Sensor 54 - INT Intercooler Coolant Low or Pump Failure Replace Water Level Sensor, Test IC W. Pump 71 - EGR EGR gas temp below acceptable level Check EGR system, (Valve/VSV/Hose/Tem This post has been edited by lagos: Jul 16, 2006 - 2:23 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jul 16, 2006 - 2:33 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 29, '03 From 캘리포니아 Currently Offline Reputation: 23 (100%) |
Hey i got code 32 on my Alltrac when i ran the codes. I dont think my AFM is bad becuase they said if it was, the car would shut off after about 5 seconds after starting the car. But mine "runs", well it idles VERY poorly. And i cant rev it past 4k RPMS. the idle is really low as well, like LOW 250rpms, sounds like the car is about to die but keeps saving itself. I was just wondering if that engine code 32 could cause this problem. Sorry to jack the thread.
Jul 17, 2006 - 7:45 AM
QUOTE(MaskedMan @ Jul 16, 2006 - 3:33 PM) [snapback]456877[/snapback] Hey i got code 32 on my Alltrac when i ran the codes. I dont think my AFM is bad becuase they said if it was, the car would shut off after about 5 seconds after starting the car. But mine "runs", well it idles VERY poorly. And i cant rev it past 4k RPMS. the idle is really low as well, like LOW 250rpms, sounds like the car is about to die but keeps saving itself. I was just wondering if that engine code 32 could cause this problem. Sorry to jack the thread. yes. -------------------- Former Team 5SFTE pro member ;)
| Lo-Fi Version | Time is now: June 24th, 2026 - 4:33 AM |
