> How many quarts of Fuild in Radiator?, We really need a sticky on this stuff
post Jul 16, 2006 - 9:18 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
I've bought some water wetter and I want to make sure I put the right amount in the Celica. I'll keep an eye on my temp gauge to see how it messures after I put this stuff in.
We really should have a sticky with info like oil capacity, radiator, steering fluid, and all that other stuff. If I can find the info, I'll try to start one.
Live Free, Be Happy
post Jul 16, 2006 - 9:21 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
isnt it a half gallon coolant and a half gallon water?
post Jul 16, 2006 - 10:14 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(LewFX @ Jul 16, 2006 - 10:21 PM) [snapback]457047[/snapback]
That sounds way to easy. I should really know this too, I just changed my radiator. I just filled it though, I didn't watch to see exactly how much I was using.
Live Free, Be Happy
post Jul 16, 2006 - 10:27 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
ive used a whole gallon of coolant in mines and it over flowed....ended up draining some coolant to add some water......i'd say about a gallon capacity
post Jul 16, 2006 - 11:41 PM
azian_advanced
Joined Apr 18, '05
From Calgary
aren't they in the car manual?
post Jul 17, 2006 - 3:55 AM
Yellow94GT
Joined Mar 17, '06
QUOTE(Bigmeanbulldog55 @ Jul 16, 2006 - 10:18 PM) [snapback]457044[/snapback]
This is from the Green Manual.
CAPACITIES
CAUTION: Some transaxles require that differential be filled
separately from transaxle. A special amount of lubricant is
required for differential. See appropriate FLUID CAPACITIES
table.
(ST) 1.8L (7A-FE) - FLUID CAPACITIES
Crankcase (Includes Filter) ........... 3.9 Qts. (3.7L)
Cooling System (Includes Heater)
A/T .................................... 7.0 Qts. (6.6L)
M/T .................................... 6.4 Qts. (6.1L)
Manual Transaxle (SAE 75W-90/API GL-5)2.7 Qts. (2.6L)
Automatic Transaxle (Dexron-II)
Dry Refill ............................. 8.0 Qts. (7.6L)
Drain & Refill ......................... 3.5 Qts. (3.3L)
(1) - Approximate quantity listed.
(GT) 2.2L (5S-FE) - FLUID CAPACITIES
Crankcase (Includes Filter) .............. 4.1 Qts. (3.9L)
A/T .................................... 7.5 Qts. (7.1L)
M/T .................................... 7.1 Qts. (6.7L)
Manual Transaxle (SAE 75W-90/API GL-5) 2.7 Qts. (2.6L)
Dry Refill ............................. 5.9 Qts. (5.6L)
Drain & Refill ......................... 2.6 Qts. (2.5L)
Differential (Dexron-II) With A/T ........ 1.7 Qts. (1.6L)
Use a clean funnel smile.gif Happy pouring!
Yellow 94GT
post Jul 17, 2006 - 10:25 AM
valerit1
Joined May 2, '06
From Nevada
QUOTE(Yellow94GT @ Jul 17, 2006 - 3:55 AM) [snapback]457166[/snapback]
CAPACITIES
table.
Yellow 94GT
Power steering - .85 Qt.
Cooling - with or without overflow reservoir?
post Jul 17, 2006 - 10:50 AM
Killswitch
Joined Feb 6, '06
From Salem, NH
Every Possible Fluid:
Air Cond Refrigerant
R-134a
- 23 OZS.
Automatic Transmission Fluid
DEXRON II ATF
1.8L Eng Drain and Refill - 3.5 QTS.
2.2L Eng Drain and Refill - 2.6 QTS.
Brake Fluid
SAE J 1703 or FMVSS No.116 DOT 3
- Check and Refill
Engine Coolant
50/50 mixture of Ethylene Glycol Antifreeze and water
1.8L Eng,Automatic Trans - 7 QTS.
Do not use alcohol type antifreeze or plain water alone.
1.8L Eng,Standard Trans - 6.4 QTS.
2.2L Eng,Automatic Trans - 7.5 QTS.
2.2L Eng,Standard Trans - 7.1 QTS.
Engine Oil
SAE 5W-30 (Below 100Deg.F), 10W-30 (Above 0Deg.F)
1.8L Eng Drain and Refill,w/Filter - 3.9 QTS.
1.8L Eng Drain and Refill,w/o Filter - 3.7 QTS.
2.2L Eng Drain and Refill,w/Filter - 4.1 QTS.
2.2L Eng Drain and Refill,w/o Filter - 3.9 QTS.
Fuel Tank
- 15.9 GALS.
Manual Transmission Fluid
API GL-3; Recommended viscosity: SAE 75W-90
2.2L Eng - 2.7 QTS.
If GL-3 is not available GL-4 or GL-5 may be used. SAE75W-90.
Hypoid gear oil API GL-4 or GL-5; Recommended viscosity: SAE 75W-90
1.8L Eng - 2.7 QTS.
Power Steering Fluid
DEXRON II ATF
- Check and Refill
This post has been edited by Killswitch: Jul 17, 2006 - 10:53 AM
Lo-Fi Version Time is now: May 9th, 2026 - 2:37 AM
