Jul 17, 2006 - 4:58 PM
well..title is pretty self explenatory. I found out today that i can order ALOT of engine internals for toyota cars. Like i can get every peice of the valve train except for cams and the actuall head its self. Any ways, i checked and i can get pistons for a 3sgte for like $45 each. will they fit?
Jul 17, 2006 - 5:10 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 29, '03 From 캘리포니아 Currently Offline Reputation: 23 (100%) |
to the best of my knowledge they would fit if you got different piston rings for it, since the 3s is a 2.0ltr and the 5s is a 2.2ltr.
Jul 17, 2006 - 6:50 PM
no.
Jul 17, 2006 - 6:59 PM
ok i take back what i said then. i was just in the mentallity that since people can fit 4agze pistons into a 7age which is .2 ltrs bigger that it could possibly work the same in this situation. sorry for the mistake.
This post has been edited by MaskedMan: Jul 17, 2006 - 7:01 PM -------------------- |
Jul 18, 2006 - 10:38 AM
just looked through the cataloge and saw the bore size is alot bigger on the 5s, nvm.
Jul 18, 2006 - 9:29 PM
Enthusiast ![]() Joined Jun 18, '06 From Aruba Currently Offline Reputation: 0 (0%) |
best thing to do is measure the bore anyways....because you will want to hone your sleeves if you are gonna put new pistons in.
I got the BEAMS 3SGE Redtop, im thinking of turboing it, and i will be putting in low compression pistons, and honing to fit the new arias pistons in..... -------------------- Toyo'd, Eibach'd, Kayaba'd & BEAMS'd :D
| Lo-Fi Version | Time is now: August 25th, 2026 - 8:40 AM |
