> replacing wheel stud
post Jul 24, 2006 - 9:24 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
do i just bang on it till it comes out the back then hammer a new one in there or what?
are the front and rear hubs the same? cause i have a spare rear hub and if it is the same i can just put that on the front instead of replacing a wheel stud at all...
post Jul 24, 2006 - 10:31 PM
front and back are COMPLETELY different..just take a look at them
the rear is bolted on via 4 bolts and the hub/bearing/spindle assembly comes as a one piece deal from the factory...where as the FRONT the hub/spindle assembly is pressed into the bearing/knuckle assembly...
to remove the wheel stud (they are press ins) get a big hammer and wack it
This post has been edited by playr158: Jul 24, 2006 - 10:31 PM
post Jul 24, 2006 - 10:48 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
thats what i thought.. i didnt have a chance to look at front today so i thought id make a post
post Jul 25, 2006 - 10:10 AM
Kadett
Joined Mar 17, '05
From The Netherlands
You have to give it a real POWERFULL smack. At least my rear studs were rusted and it took alot of WD-40 2 days of soaking it in and still alot of powerfull blows before they came loose. You may have to remove the E-brake pads (dont know if you have drums or disks) to give room for the studs to come out.
To put a newone in (I replaced them with longer studs) I used a reversed 20mm socket put it on the stud then place a wheelnut on the stud+socket. Fully spray the back of the splines with WD-40 or Siliconespray and pull the stud into the hub. You may want to use a breaker bar so the wheel is locked and you can use all your power to pull the stud in. I replaced but front and rear studs in 3 days and felt it 3 days after in my lower arms.
This post has been edited by Kadett: Jul 25, 2006 - 10:11 AM
post Aug 11, 2006 - 4:23 PM
jdg371
Joined Jun 14, '05
QUOTE(Kadett @ Jul 25, 2006 - 11:10 AM) [snapback]460829[/snapback]
where did you get your "longer studs" and how long are they compared to stock
post Aug 12, 2006 - 1:56 AM
Kadett
Joined Mar 17, '05
Longer studs came with the Spacer kit from H&R DRS Series. So if you order 20mm spacers, you get 20mm longer studs.
Lo-Fi Version Time is now: August 12th, 2026 - 12:46 AM
