Jul 25, 2006 - 7:55 PM
Okay, Two weeks ago-ish I put my coilovers on. All is gravy and I am happy. Several days go by and all the little noises go away..Except for one that seemed to develop as the days went by. Whenever I turn my wheels (moreso to the left, but does it to the right as well) I get a clunking. I took my dad out on a drive last night to see what he thought, but it wouldn't do it. I had to come to a complete stop and crank the wheel back and forth to get it to pop and clunk.
Here is what I think... Maybe there is not enough lube on my strut bearings Maybe a CV joint is on its way out, or a torn boot... I don't see any grease on the firewall and around the engine bay, so I'm not sure of this option. Soooooo I want to re-grease my strut bearings, but I don't want to take the suspension apart, because that would be a b*tch. Can I drop it out of the strut mount and get to it without taking it apart from the brakes? Or do I have to dismantle everything all over again? Thoughts and Opinions? -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Jul 25, 2006 - 9:37 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Feb 18, '06 From NB, Canada Currently Offline Reputation: 12 (100%) |
I'm pretty sure a strutch bearing won't make a clunking sound by turning the wheel at a stop. theres nothing to make a clunk, its two flat surface on each other!
Its probably related to the coilover imo. Cause a CV joint wouldnt make that much noise either at a stop. But I can be wrong. This post has been edited by Rayme: Jul 25, 2006 - 9:38 PM -------------------- ![]() -Rémy 02 SiR, 08 250R |
Jul 25, 2006 - 9:57 PM
Enthusiast ![]() ![]() Joined May 25, '06 From South Carolina Currently Offline Reputation: 3 (100%) |
mine do it to, if u find an answer i need it also
Jul 25, 2006 - 10:08 PM
check the tie rods and tie rod ends for loosenes, also the balljoints.
Jul 27, 2006 - 4:20 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 13, '03 From California Currently Offline Reputation: 2 (100%) |
if you have those ebay coilovers they will clunk, clank, smack, rub like a mofo
also the upper strut mount may be stripped and dry causing that noise...i know that was a problem for me. -------------------- 2011 Spice Orange Mini Cooper
2011 Alpine White BMW E92 M3 gone but not forgotten 2008 Space Grey BMW Z4 ///M 2009 Black Honda Civic LX Coupe 2006 Magnetic Black Nissan 350Z 2007 Crimson Red BMW 335i Coupe |
Jul 27, 2006 - 5:28 PM
QUOTE if you have those ebay coilovers they will clunk, clank, smack, rub like a mofo also the upper strut mount may be stripped and dry causing that noise...i know that was a problem for me. If you call Ground Control ebay coilovers.. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Jul 27, 2006 - 5:58 PM
personally i would get rid of those coilovers and get some nice springs.
Jul 27, 2006 - 6:31 PM
QUOTE personally i would get rid of those coilovers and get some nice springs. Then you start the fund. I'm not going to get rid of them right after I put them on. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Jul 27, 2006 - 8:01 PM
This sounds awfully familiar to the time when one of my front calipers was hanging by 1 bolt to the brackets. It Clunked and clanked everytime I turned and went over bumps. It became so worse that when I inspected it, it fell off after 1 turn.
Jul 27, 2006 - 8:05 PM
I will be able to get up under there tomorrow and I shall report back my findings.
| Lo-Fi Version | Time is now: August 29th, 2026 - 7:41 PM |
