> Clutch Pedal, Hard to Press in!!!
post Jul 28, 2006 - 11:27 PM
Dunners
Joined Oct 25, '05
From Brisbane, Australia
Hey guy's,
Just wondering if anyone else's clutch pedal is hard to push in. I've never really noticed it but I drove a mates toyota the other day and his was so easy. Is there anything that determines how hard it is to push down or if i could make it any easier? thanks for your help.
post Jul 28, 2006 - 11:46 PM
Shocker
Joined Mar 23, '06
From Nashville Tennessee
My clutch is also hard to push in??? at least much harder than any other 5spd ive ever driven
post Jul 31, 2006 - 6:24 PM
laff09
Joined Jul 28, '06
From Delaware
QUOTE(Shocker @ Jul 28, 2006 - 11:46 PM) [snapback]462726[/snapback]
Same w/ my 94' ST. I drove a buddies 6 speed 00' Celica and a 6 speed 05' Sentra Spec-R, both had feather light clutch pedals.
post Aug 1, 2006 - 4:32 PM
Magic
Joined Mar 30, '03
From Cyprus
On the ST205 you can adjust the pedal but this has just to do with the engage point that you want to give to your clutch (high or low),i think you can do this adjustment also on the ST202 pedal.
I dont know if this will help but i changed my clutch (ACT Organic Disc and ACT Pressure plate) with ORC409 Super Single Kit last week and i feel my clutch very light!!!Using the ACT was very hard to push the pedal,i m also using Cusco Cross Mission Oil.
post Aug 1, 2006 - 4:39 PM
Valo666
Joined May 15, '05
From Toronto
ours is hard to push in because mainly its a hydrolic clutch rather than a cabel clutch. Also, depending on how heavy of a pressure plate you have, it makes it harder. my buddies 180sx from japan has a a stage 3 race clutch in it and his clutch feels like its broken. You know when you pump the breaks with the car off??..thats what his clutch feels like all the time. But at the same time also due to the way our clutch lines run to the tranny, it makes it stiffer too. I know 95% of my friends power shift the car or rev it and dump the clutch because they cant find the release point or get used to hydro clutching. Personaly, i like it stiffer.
post Aug 1, 2006 - 5:13 PM
ed_celica94
Joined Jul 13, '06
From san antonio .tx
try changing your master and slave cyilinder i did mine. and its alote eazyer to push in.
post Aug 1, 2006 - 5:17 PM
ExSane
Joined Apr 17, '06
From under your bed.
I had a problem before where my clutch wouldn't even grab. The clutch was very easy to press in at the time. But once I took it to the shop, they replaced my clutch as well as resurfaced fly wheel, my clutch has been hard to press in. To me that is a sign saying that the clutch is good and strong. biggrin.gif
Lo-Fi Version Time is now: September 14th, 2026 - 9:04 AM
