> mr2 swap vs st205, alternater position????
post Aug 2, 2006 - 6:43 PM
urbandork
Joined Jul 16, '04
From Los Angeles
ive noticed that on the 3rd gen 3sgte in the mr 2 the alternator is on the back of the engine rather then the front. How does this affect a swap when using an mr2 clip?????
post Aug 2, 2006 - 6:45 PM
XS4lv1Truch0x
Joined Dec 9, '05
From Long Beach
i heard that you are going to have to fabricate a bracket to mount it correctly.
i dunno i read that somewhere in the stickies. but other than that, i guess it should all be the same.
oh yea and if you use an mr2 tranny ur gona have to do something to it to make it fwd or something.
Is this good enuff 4 ya? :D
post Aug 2, 2006 - 6:47 PM
yungazzdriver
Joined Feb 15, '05
From Frederick, Maryland
QUOTE(urbandork @ Aug 2, 2006 - 6:43 PM) [snapback]464711[/snapback]
none at all, its actually better to have the alternator in the rear imo gives ya more space in the front!!
post Aug 2, 2006 - 6:49 PM
unless you really know what your doing.... getting an mr2 clip is going to give you more headaches then its worth. there is lots of little stuff that needs to be relocated to make everything work. not to mention that your harness will have to be totally redone to work in your fwd car.
post Aug 2, 2006 - 7:35 PM
gtfc115
Joined Aug 14, '04
From Toledo, Ohio
i did the mr2 swap.
i'm very happy with the results, but i dont even want to tell you how long it took and how much it cost and all the BS in between.
dont do it...get the 205 clip
This post has been edited by gtfc115: Aug 2, 2006 - 7:52 PM
post Aug 2, 2006 - 8:22 PM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(gtfc115 @ Aug 2, 2006 - 5:35 PM) [snapback]464725[/snapback]
Seriously... All the brackets 'n stuff should bolt right in place for all the parts. That, and you get the sweet AWIC.
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
Lo-Fi Version Time is now: May 24th, 2026 - 5:34 PM
