Aug 13, 2006 - 2:02 PM
Enthusiast Joined Aug 13, '06 From Lansing Currently Offline Reputation: 0 (0%) |
im having trouble changing my drivers side headlight bulb ive removed the bolts i can see but it still seems to be attacthed at the bottom, i was wondering anyone else has had this promblem
Aug 13, 2006 - 2:06 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
you dont have to take out any bolts for the bulb, just twist and pull out
Aug 13, 2006 - 2:18 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Hollywood, FL Currently Offline Reputation: 0 (0%) |
If your change the actual headlight, you need to remove the bumper, which has about 25 bolts. If your changing the bulb all you do is twist it and pull it out, simple.
Oh btw there are 3 bolts that hold the headlight down. This post has been edited by bloodrain: Aug 13, 2006 - 2:18 PM -------------------- To live, is to suffer
To survive, thats to find meaning, in the suffering.... ![]() |
Aug 13, 2006 - 2:55 PM
the trouble im having is getting to the bulb
Aug 13, 2006 - 3:16 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 6, '06 From massachusetts Currently Offline Reputation: 30 (97%) |
QUOTE(Craig14Nielsen @ Aug 13, 2006 - 3:55 PM) [snapback]468559[/snapback] the trouble im having is getting to the bulb just look at the back side of the headlight. grab the little plastic piece that holds the bulb and twist and pull. the should be it. |
| Lo-Fi Version | Time is now: June 23rd, 2026 - 8:58 PM |
