Sep 8, 2006 - 5:59 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '05 From Toronto, Ontario Currently Offline Reputation: 8 (100%) |
I was wondering if the replica of the C-ONE front bumper from Vis (the Zyclone front bumper) can fit the GT-4 Front turn signals without modification...
Reason I'm askin is cause a) usdm ones don't seem to fit without modification b) I always see people modify the bumper to fit the slanted usdm ones instead of getting gt-4 ones... c) from the body kit guide, the GENUINE st-205 c-one front bumper seems to have a rectangular shaped opening for the gt-4 turn signals while the GENUINE st-204 c-one front bumper seems to have a sort of parallelogram shaped opening for what seems like the regular turn signals now, if the gt-4 turn signals DO fit... do the usdm bulb connectors fit into the GT-4 turn signals? or does it require modification? thanks. ========================== had another question... if i were to put jdm side indicators on my fenders in place of the usdm ones by extending the original wiring... would that connector for the usdm side indicator fit into the jdm side indicators? these were the ones i was looking at: http://cgi.ebay.com/Clear-Side-Indicators-...1QQcmdZViewItem o yea, and if u know where to buy cheaper ones, it'd be nice if u could let me kno too =) thanks This post has been edited by elvasoshexai: Sep 8, 2006 - 6:05 PM -------------------- |
Sep 8, 2006 - 11:59 PM
QUOTE(elvasoshexai @ Sep 8, 2006 - 5:59 PM) [snapback]477661[/snapback] I was wondering if the replica of the C-ONE front bumper from Vis (the Zyclone front bumper) can fit the GT-4 Front turn signals without modification... Reason I'm askin is cause a) usdm ones don't seem to fit without modification b) I always see people modify the bumper to fit the slanted usdm ones instead of getting gt-4 ones... c) from the body kit guide, the GENUINE st-205 c-one front bumper seems to have a rectangular shaped opening for the gt-4 turn signals while the GENUINE st-204 c-one front bumper seems to have a sort of parallelogram shaped opening for what seems like the regular turn signals now, if the gt-4 turn signals DO fit... do the usdm bulb connectors fit into the GT-4 turn signals? or does it require modification? thanks. ========================== had another question... if i were to put jdm side indicators on my fenders in place of the usdm ones by extending the original wiring... would that connector for the usdm side indicator fit into the jdm side indicators? these were the ones i was looking at: http://cgi.ebay.com/Clear-Side-Indicators-...1QQcmdZViewItem o yea, and if u know where to buy cheaper ones, it'd be nice if u could let me kno too =) thanks the connectors for the usdm turn signals will NOT fit the gt4 turn signals socket.. but you can keep using your original socket and bulb but in order to make them fit the gt4 turn signal housing, one of the notches on the housing will need to be cut 1mm wider. that's it, it only takes 5 minutes.. you can just use a utility knife to do it.. the connectors for the usdm parking lights fit the jdm side repeaters perfectly.. on a side note, there is a mod located in the how-to on the main page that will allow you to wire them up to the turn signals if you want oem side indicators (amber), they cost $29 for the pair. i'm assuming the gt4 turn signal fits the genuine st205 c-one front perfectly.. but since the replicas are based on the usdm or st202/at200 models, i'm not so sure if they fit in the same way.. but i'm sure they're a lot easier to make them fit than any other turn signals. -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Sep 9, 2006 - 1:17 AM
QUOTE(azian_advanced @ Sep 9, 2006 - 12:59 AM) [snapback]477754[/snapback] the connectors for the usdm turn signals will NOT fit the gt4 turn signals socket.. but you can keep using your original socket and bulb but in order to make them fit the gt4 turn signal housing, one of the notches on the housing will need to be cut 1mm wider. that's it, it only takes 5 minutes.. you can just use a utility knife to do it.. the connectors for the usdm parking lights fit the jdm side repeaters perfectly.. on a side note, there is a mod located in the how-to on the main page that will allow you to wire them up to the turn signals if you want oem side indicators (amber), they cost $29 for the pair. i'm assuming the gt4 turn signal fits the genuine st205 c-one front perfectly.. but since the replicas are based on the usdm or st202/at200 models, i'm not so sure if they fit in the same way.. but i'm sure they're a lot easier to make them fit than any other turn signals. thanks for the info yea i would think the replicas are based on the st202/at200 models but apparently the usdm turn signals don't fit properly.. and since i've never seen someone with a replica front use the gt-4 ones... so i wasn't sure. i wonder if the clear jdm side indicators are the same as the oem ones tho... -------------------- |
| Lo-Fi Version | Time is now: September 15th, 2026 - 2:37 PM |
