> Oil filter numbers
post Sep 9, 2006 - 11:44 PM
Steevo
Joined Jul 19, '06
From Colorado
7AFE takes the same filter a lawnmower takes, upon finding the Fleetguard part number I found this out.
With a hour of research I have found a bigger and better interchange four this motor.
LF655 Sightly larger but clears everything and flows 50% more oil at the same pressure.
Stock filter has 3/4-16 UNS thread, and the LF655 has 3/4-16 UNF thread. The difference being a radius at the top and bottom of the thread that matters not.
I just changed mine and it works great save a strap oil filter wrenche will not clear the gap between the exhaust manifold and filter housing.
Filteration is better too as it is a fiberglass media with synthetic adhesive as opposed to paper.
I also am trying 0W40 synthetic that has a flow rate less than a standard 15W oil would at +200F and a pour point of -79F
post Sep 9, 2006 - 11:53 PM
thanks for the heads up, i wonder if it'll clear my ebay header?
Lo-Fi Version Time is now: August 11th, 2026 - 6:09 PM
