> removing doors, wiring harness
post Sep 13, 2006 - 12:01 PM
Rayme
Joined Feb 18, '06
From NB, Canada
I need to remove the doors..is the wiring harness disconnected from inside the door or inside the car?
Also by the way..my hinges are really lose. is there some sort of bushings in there, or I need new hinges???
-Rémy
02 SiR, 08 250R
post Sep 13, 2006 - 12:22 PM
if you have AIM i can give you quick how to + pics
basically down by your feet there are 2 side kickpanels
remove them(you'll need to remove the door sill trim first)
once you remove both sides you'll see a mass of plugs...the door is 2 plugs they coming through a tunnel in the wall
i'm pretty sure they are white plugs just un plug them and pull them through the hole and remove with door...doors are heavy so becareful not to drop them
and if you want i also have a set of door hinges for sale
This post has been edited by playr158: Sep 13, 2006 - 12:27 PM
post Sep 13, 2006 - 2:56 PM
Rayme
Joined Feb 18, '06
From NB, Canada
are those hinges new? whats your ballpark…
thanks for the wiring info, I'll crawl under the dash then!
-Rémy
02 SiR, 08 250R
Lo-Fi Version Time is now: August 9th, 2026 - 12:50 PM
