Sep 15, 2006 - 10:07 PM
New Pics of my actuall turbo. im impressed. this thing looks brand new, rebuilt obviously or something. looks cherry
pics. speak for themself. ![]() ![]() ![]() After doing a few month of research a while back i knew i wanted to try this turbo. ![]() that is an hY35, the difference between the Hx35 / Hy35 is the hy is always single entry, where as the hx is twin, like our stock ct-26 so i expect it to spool better than the hY would. Some other miner differences are the V-band clamp on the hy where the hx doesnt have this. heres a flow map Very efficient turbo. QUOTE The HY35W can sustain up to 4.2 pressure ratio (That means a little more than 4 times the atmospheric pressure) and can deliver about 52 lb/min. And it won't choke, the compressor wheel and turbo wheel are a good match. (Pulled from Torn81 over at MR2oc.com) Basicly this turbo will flow alot of air without choking like the ct-26 does. so 15psi on a hx35 will be tottally different than 15psi on a ct-26 because the turbo can physically flow more air while being in a better efficiency range. Also since its for a diesel motor designed to last over 300,000 miles the bearings it uses are alot more durable than most other turbos, with the exception of Ball bearing maybe. Dsms, Hondas and even volvos have been using holset turbos for a while now, proving itself as a good inexpensive turbo suitable for any small displacement motor, such as the 3sgte. This post has been edited by x_itchy_b_x: Sep 30, 2006 - 12:26 AM -------------------- |
Sep 15, 2006 - 10:09 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) |
nice...
Sep 15, 2006 - 10:15 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jul 9, '04 From Las Vegas USA Currently Offline Reputation: 14 (100%) |
Cool find, good luck! I also like the name reminds me of holeshot ( like in drag racing, nothing nasty) HAha!
Sep 16, 2006 - 4:08 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 10, '05 From Monroe, WA Currently Offline Reputation: 6 (100%) |
im curious what you are going to mount it with? I have one of those on my cummins ram2500
-------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
Sep 16, 2006 - 7:42 AM
how are you planning on tuning for that itch?
Sep 16, 2006 - 10:51 AM
wolfcatz rail, afregulator, 800cc's, as for mounting they sell ct to t3 flages or ill make one. wanna run external wg. weld the flapper closed.um for tunning. im still no to sure. the rom tune is usless to me, i could try emanage ultimate, but i dot want that to not work out, i know the regular emanage is pretty nice and can run a fully modified motor (ive tuned a car to get 120 extra hp just playing with numbers. the car might be off the road fora while till i decide weather i should just go nemisis ems. it sucks working everyday but i have a goal set and i dont mind working for it. i want atleast 350whp
and thats being modest. -------------------- |
Sep 16, 2006 - 11:21 AM
sounds like your on the right track. the nemesis is a good EMS but people have had issues with it picking up "ghost knock". you probably have heard about that i just dont think I would want to deal with it, even though they say it has be addressed.
Sep 17, 2006 - 6:22 AM
QUOTE(celicast3sgte @ Sep 16, 2006 - 12:21 PM) [snapback]480404[/snapback] sounds like your on the right track. the nemesis is a good EMS but people have had issues with it picking up "ghost knock". you probably have heard about that i just dont think I would want to deal with it, even though they say it has be addressed. that was only an issue on the earlier releases of it. -------------------- Former Team 5SFTE pro member ;)
Sep 30, 2006 - 12:27 AM
check out the exhaust side difference Mhhh.
Sep 30, 2006 - 12:48 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '04 From Illinois Currently Offline Reputation: 0 (0%) |
QUOTE(x_itchy_b_x @ Sep 16, 2006 - 10:51 AM) [snapback]480400[/snapback] wolfcatz rail, afregulator, 800cc's, as for mounting they sell ct to t3 flages or ill make one. wanna run external wg. weld the flapper closed.um for tunning. im still no to sure. the rom tune is usless to me, i could try emanage ultimate, but i dot want that to not work out, i know the regular emanage is pretty nice and can run a fully modified motor (ive tuned a car to get 120 extra hp just playing with numbers. the car might be off the road fora while till i decide weather i should just go nemisis ems. it sucks working everyday but i have a goal set and i dont mind working for it. i want atleast 350whp and thats being modest. At those power levels, a standalone is the only wise choice. Looks like an interesting turbo. Good luck. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
| Lo-Fi Version | Time is now: June 10th, 2026 - 8:59 AM |
