> FS FEELER: CT20B, no shaft play, ceramic wheel, bolt-on for gen2
post Sep 28, 2006 - 11:35 AM
CilverSeliST205
Joined Nov 3, '05
From Chicago Suburbs
I'm thinking about upgrading to TD06/T3T4/GT28 or something among these lines and I would like to know how much i can get sell my CT20b for, so far i seen them for sale in range $600-$800, if i do not get a decent offer I will put this ad on celicatech and mr2oc but i want you guys to have first chance to order yours GENUINE CT20B:
- 2 months ago i was changing the DP so i checked for shaftplay, and to my suprise is nonexistant, i say no shaftplay by hand but maybe micrometer type tool is required for that kind of test i dont know.
- Turbo timer always used, even though CT20b is also water cooled.
- Oil changed religiously every 3000 miles
- direct bolt-on for gen2 3SGTE, expect quicker spool-up and safe 16 psi all the way to the redline
- ceramic turbine, quicker spool-up and fear not the myth of it shattering, unless you planning on 20+psi daily (if so, buy a different turbo)
- I will post pictures if i get a reasonable offer, it is still on my car and this is just a feeler.
QUOTE(tufy @ Jul 19, 2006 - 7:40 AM) [snapback]458074[/snapback]
i dont drive fast, i just fly low
post Sep 29, 2006 - 8:14 AM
CilverSeliST205
Joined Nov 3, '05
post Sep 29, 2006 - 8:48 AM
jgreening
Joined Jan 17, '04
From Illinois
Jerry, are you going standalone?
post Sep 29, 2006 - 3:52 PM
CilverSeliST205
Joined Nov 3, '05
QUOTE(jgreening @ Sep 29, 2006 - 8:48 AM) [snapback]485233[/snapback]
Im pretty set for Apexi power FC - commander + datalogit!!
Why would you like to know ?
post Sep 29, 2006 - 10:15 PM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(CilverSeliST205 @ Sep 29, 2006 - 3:52 PM) [snapback]485408[/snapback]
Just keeping up with your build! I was also going to give you a warning about doing a turbo upgrade on gen III on the stock ECU. I should have known you wouldn't need my warnings. Check out this post (post #33) from Ricky B:
Ricky's Post
post Oct 4, 2006 - 9:34 AM
CilverSeliST205
Joined Nov 3, '05
QUOTE(jgreening @ Sep 29, 2006 - 10:15 PM) [snapback]485552[/snapback]
Ricky's Post
Good info thanks man! I am glad that you still visit here even after the celica phase thumbsup.gif
post Oct 4, 2006 - 10:06 AM
jgreening
Joined Jan 17, '04
From Illinois
BTW, I would not recommend a gt28rs if you are trying to "upgrade" from the ct20b. If you are going to have a new fuel system, you might as well go with the gt3076r - with the smaller A/R. It should hit 200 ft/lbs by 3700 RPMs and still be able to hit the upper 300's with relative ease.
post Aug 15, 2011 - 10:38 AM
Detatch
Joined Sep 28, '09
From Washington, MO
price?
post Aug 15, 2011 - 11:42 AM
Neon90424
Joined Jan 19, '11
From Paraguay, Winchestertonfieldville
You can read my thread if you want to see some of the things I went through with a different turbo on stock 3rd gen ecu, I am going to try using a uego wideband with the 0-1v output to the ECU and the 0-5v to a gauge and see how it reacts...but it definitely pulls timing even with water/alky injection
Lo-Fi Version Time is now: September 3rd, 2026 - 6:08 AM
