Oct 11, 2006 - 12:00 PM
Enthusiast ![]() Joined Oct 4, '05 From Rineyville, KY Currently Offline Reputation: 0 (0%) |
I've pretty much taken car of all the vibrating parts on my car except for one piece. It's that part around the license plate (see picture if you can't figure out what I'm talking about). Does anybody know how to remove this piece?
This post has been edited by Mystify.: Oct 11, 2006 - 12:01 PM |
Oct 11, 2006 - 12:20 PM
Enthusiast ![]() ![]() Joined Mar 24, '06 From Aloha, Oregon Currently Offline Reputation: 5 (100%) |
you could put some clear silicon in all the gaps and dynamat on the inner trunk wall...
Oct 11, 2006 - 7:31 PM
![]() Enthusiast ![]() ![]() Joined Jul 22, '06 From San Antonio / georgetown, Texas Currently Offline Reputation: 9 (100%) |
sooo did that stop the rattles? cause i kind of have a hatred for rattles. ill be dynamating my car in a week or so but i dont know if thats enough.
Oct 11, 2006 - 8:28 PM
Enthusiast ![]() ![]() Joined Nov 23, '05 From Charleston, WV Currently Offline Reputation: 1 (100%) |
You have to remove tail lights first. There are 3 screws each tail light from inside. Take those off and everything else is easy. Couple screws and just pop the licence piece out. Off course remove the licence plate first.... Hope it helps
This post has been edited by miro1975: Oct 11, 2006 - 8:29 PM |
Oct 11, 2006 - 11:30 PM
Enthusiast ![]() ![]() Joined Sep 1, '06 From Michigan Currently Offline Reputation: 0 (0%) |
what i did, was bought some foam, and glued it to the plate, (it'd come off trust me) That way its atleast not hitting metal on metal, why you trying to decrease vibrations? trying to raise SPL for subs? e.Dead is supposed to be amazing for that if you are
Oct 11, 2006 - 11:57 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jul 9, '04 From Las Vegas USA Currently Offline Reputation: 14 (100%) |
I used dynomat under the part where the plate mounts. Worked really well when I use to run SPl contest.
Oct 12, 2006 - 8:47 AM
Sorry I came on so late. I went out last night and totally forgot I made this thread.
QUOTE(brthrurik @ Oct 11, 2006 - 1:20 PM) [snapback]490304[/snapback] you could put some clear silicon in all the gaps and dynamat on the inner trunk wall... I've already put sound deadener all over the trunk and that didn't fix it. It's just coming from that one plastic piece on the outside. QUOTE(miro1975 @ Oct 11, 2006 - 9:28 PM) [snapback]490479[/snapback] You have to remove tail lights first. There are 3 screws each tail light from inside. Take those off and everything else is easy. Couple screws and just pop the licence piece out. Off course remove the licence plate first.... Hope it helps Thank you very much, I'll try that today when I get a chance. QUOTE(n1ckz0r @ Oct 12, 2006 - 12:30 AM) [snapback]490569[/snapback] what i did, was bought some foam, and glued it to the plate, (it'd come off trust me) That way its atleast not hitting metal on metal, why you trying to decrease vibrations? trying to raise SPL for subs? e.Dead is supposed to be amazing for that if you are Oh trust me, it's not the actual license plate (I have 3 layers of sound deadening on that QUOTE sooo did that stop the rattles? cause i kind of have a hatred for rattles. ill be dynamating my car in a week or so but i dont know if thats enough. Dynamat your car, trust me it will improve the sound of your speakers. The main parts you want to put the sound deadener are in the trunk and in your door panels. Since you probably won't get rid of all the rattle on the first application, I would suggest you order a little extra just in case. This post has been edited by Mystify.: Oct 12, 2006 - 8:54 AM |
Oct 17, 2006 - 4:06 PM
I HATE rattles... I'd rather take a panel out than have it rattle.
| Lo-Fi Version | Time is now: September 2nd, 2026 - 12:29 AM |
