> Swapped wiring problem, Cant get the CEL to come on
post Oct 20, 2006 - 2:50 AM
6gsillyca
Joined Jan 13, '06
From UnderTheGround403
I have a thread in the electrical sub-forum, but figured my problem is swap-wiring related.
Im trying to pull some codes from the ECU and I cant get the CEL to come on. The bulb is not burnt and the cluster itself is good so Ive narrowed it down to a problem in the cars wiring, somewhere. There are 2 other lights that dont come on (cruise and oil) but am not worried about these. I was told the cruise works but havent actually tried it yet, and there is an oil pressure gauge hooked up. No big deal. The one I need is the CEL...
Can anyone tell me if there is another way to pull codes w/o using the CEL
or
Is there another way to get the CEL to come on
Sorry for all the confusion
post Oct 20, 2006 - 3:15 AM
who did your harness?
post Oct 20, 2006 - 9:06 AM
Art, he has jgreening's former car.
http://www.6gc.net/forums/index.php?showtopic=42288
post Oct 20, 2006 - 10:33 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Jamasco did the wiring.
post Oct 20, 2006 - 11:00 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
To do this without the CEL of the combonation meter just put a test light between +B and W of the dignostic box and then bridge TE1 and E1. Count the flashes on the test light.
post Oct 20, 2006 - 11:51 AM
6gsillyca
Joined Jan 13, '06
Thanks, this is what I was looking for
post Oct 24, 2006 - 12:13 PM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(6gsillyca @ Oct 20, 2006 - 2:50 AM) [snapback]494035[/snapback]
or
The cruise works and the light does come on. Sometimes the cruise controller arm seperates at the end and needs to be pushed back together. I always meant to superglue that part but just never got around to it since you can just snap it back in place.
I don't know about the oil light.
post Oct 25, 2006 - 1:12 AM
6gsillyca
Joined Jan 13, '06
Where on the end neds to be puched back in?
post Oct 25, 2006 - 5:14 PM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(6gsillyca @ Oct 25, 2006 - 1:12 AM) [snapback]495827[/snapback]
Take a look at it....you will see what I mean.
post Oct 26, 2006 - 12:42 AM
6gsillyca
Joined Jan 13, '06
Ok, when I pick her up from the shop ill do that. Would it not being connected cause it to not "click"? the on/off button did not "click" last time I checked it
post Oct 26, 2006 - 11:12 AM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(6gsillyca @ Oct 26, 2006 - 12:42 AM) [snapback]496219[/snapback]
by "click" do you mean make a sound? It doesn't make a sound when it is engaged. The controller arm for the cruise pops open sometimes and then the cruise wont work. You can just snap it back in place and then its fine. Its no big deal but you could easily fix it forever by just using two drops of superglue.
post Oct 27, 2006 - 12:42 AM
6gsillyca
Joined Jan 13, '06
QUOTE(jgreening @ Oct 26, 2006 - 10:12 AM) [snapback]496323[/snapback]
No, the button at the base (end) of the arm. On my GT-S, when I push it in, it "clicks" in and sits in a bit. Almsot like the climate buttons, when you push it "on" it clicks in and when you turn it off, it clicks out.
post Oct 27, 2006 - 1:05 AM
6gsillyca
Joined Jan 13, '06
Back to original topic:
I tried what Wannabe said to do, bridge test light between B+ and W and a paperclip between e1 & te1, but the test light does not blink like the CEL should. It is just a solid light (no blinking).
Is there a way I can check the wiring harness to see if the CEL is hooked up properly?
post Oct 27, 2006 - 10:34 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Have you asked Jay about how to check codes? I'm sure he could tell you... If all else fails you can do it right at the ECU. Just like I said to do at the diagnostic box. Bridge TE1 and E1 while putting a test light between +B and W.
post Oct 27, 2006 - 11:24 AM
6gsillyca
Joined Jan 13, '06
I am asking him, but figured I would post here, just incase some of you know the answer also. Im going to assume all else did fail. The light in the dash doesnt come on (even when you turn the key to ON, all the other light light up but that one). Like I have posted before, I did try going straight to the ECU. I bridged B+ and W with the test light, and e1 and te1 with a paperclip. All that happened was the test light came on solid, no blinking.
A couple other things I noticed about the diag box is; there is some sort of grease smeared inside. Is this good? And the second is the terminals themselves. Some look like (uu) while other looks like their missing the terminal or only have half of it (u).
EDIT: I just recieved a PM from him regarding the matter, and he doesnt seem to know the answer. He has never had to pull any codes.
post Oct 27, 2006 - 1:29 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE(6gsillyca @ Oct 27, 2006 - 11:24 AM) [snapback]496783[/snapback]
The grease in the diagnostic box is normal. Get a picture of the terminals. I can't figure out what you mean by they are missing or only have half of it.
I don't know if it matters but I'm pretty sure you have an MR2 ECU. Some of the pin locations at the ECU may be different. I'll check when I get home tonight and I'll show you EXACTLY what you need to do.
post Oct 27, 2006 - 7:53 PM
6gsillyca
Joined Jan 13, '06
Yes, thank you. I do have a 93 mr2 ecu. if it matter the engine and tranny are from the same mr2 i believe.
EDIT: it is also the JDM ECU if that makes a difference
This post has been edited by 6gsillyca: Oct 27, 2006 - 8:08 PM
post Oct 27, 2006 - 8:01 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
WOAH hold up. The W in the diagnostic block has power coming to it, it needs to be GROUNDED, not jumped to +B which is positive power. The ECU ground the W circuit when it needs to turn the CEL on, power comes down from the 15amp guage fuse (usually) and then to the light, then to the ECU and the diagnostic terminal.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Oct 27, 2006 - 8:22 PM
6gsillyca
Joined Jan 13, '06
So to pull a code, Id need to bridge e1 and te1 w/ a paperclip. Put a wire into W and ground the other end somewhere, and then what?
Could my CEL not be coming on because the W circut in the ECU isnt grounded properly?
If I ground W and bridge e1/te1 will the CEL in the dash come on and flash?
post Oct 27, 2006 - 11:32 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE(Dr_Tweak @ Oct 27, 2006 - 8:01 PM) [snapback]496921[/snapback]
-Doc
His CEL isn't working... so W won't have any power coming to it, that is why he is simulating the CEL with a test light between +B and W just like the original circuit... +12V to bulb then on to ECU pin W which is ground for the circuit when the CEL is on. If he just put a test light between W and chassis ground the light would stay lit constantly even if the ECU was trying to display codes.
Lo-Fi Version Time is now: August 31st, 2026 - 10:23 PM
