> 3sge NA heads, what difference between the 1g/2g/3g???
post Oct 26, 2006 - 12:09 AM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
i was ownderin if they would fit the 5s block?....any gen GE heads would fit?......
post Oct 26, 2006 - 1:06 AM
Punch
Joined Jan 29, '04
From Brooklyn moved to Miramar Florida
1st gen head (130 HP) smaller cams
2nd gen head (160hp) smaller ports, bigger cams
3rd gen head (???hp) shim n bucket, better flowing
I have a 2nd gen (3sge) head a sale
post Oct 26, 2006 - 1:20 AM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
QUOTE(Punch @ Oct 26, 2006 - 1:06 AM) [snapback]496222[/snapback]
yea?..what other parts do i need in order to install this>?...
post Oct 26, 2006 - 2:50 AM
nsxtypeR
Joined Jan 3, '06
From The Netherlands
3rd gen has 175 hp
JDM ST205
post Oct 26, 2006 - 3:54 AM
BLADDER_MASTER
Joined Dec 8, '04
QUOTE(DeW_H0e_GT @ Oct 26, 2006 - 1:20 AM) [snapback]496227[/snapback]
Basically you're going to need a complete 3S-GE to source all the parts necessary to run the head. Either that or run a custom setup.
1st, 2nd, and 3rd gen 3S-GE heads have been successfully swapped onto 5S-FE blocks. Only the 4th gen BEAMS 3S-GE head hasn't been done.
This post has been edited by BLADDER_MASTER: Oct 26, 2006 - 5:33 AM
post Oct 26, 2006 - 8:32 AM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
but what benefits to havin a whole 3sge compared to mating to a 5sfe block?.....besides, havin a whole buncha torque... wink.gif
post Oct 26, 2006 - 2:08 PM
BLADDER_MASTER
Joined Dec 8, '04
QUOTE(DeW_H0e_GT @ Oct 26, 2006 - 8:32 AM) [snapback]496265[/snapback]
The fact that with a 3S-GE all you need to do is just drop it in, wire it up, and you're good to go (Thats if you have everything of course). Mating it to a 5S block requires you to do the same but you will need to do some more things in order to get it to work properly. Like possibly having to modify your 5S-FE block to match the 3S-GE's head water passages. To get a better idea, look for 5S-GTE swap guides. Ignore the turbo-related aspects of it and you'll get an idea of what to expect.
post Oct 29, 2006 - 10:19 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Search the forums about the '5SGE' build. I've posted a LOT about the drawbacks. The short version, high rpm head on a low rpm block = waste of time.
As for the heads... 1st gen were the TVIS versions, 2nd gen were the first smallports, 3rd gen were the second smallports with underbucket shims, 4th were the Beams redtop, 5th were the dual vvti Beams Blacktop.
Lo-Fi Version Time is now: June 24th, 2026 - 4:34 AM
