> More HP for my Power Windows!
post Nov 14, 2006 - 6:02 PM
DVSBastard
Joined Jun 8, '04
From Sydney, Australia
What I mean is my power windows have seemed to slow down a fair bit over the ages and I would like to get them back up to speed!
A couple of suggestions I have been given (but am yet to try):
Silicone spray surrounding seals
Lubricate window tracks
Replace / recondition the motors (not too keen on that one)
Mini NOS kit for my windows
However, I am more after as quick a fix as possible (i.e. something that doesn't require me to remove all the door trims, motors, etc).
Does anyone have any suggestions, or has anyone done anything about a similar power window speed issues?
post Nov 14, 2006 - 6:09 PM
94celicadude
Joined Mar 28, '04
From St.Louis
QUOTE(DVSBastard @ Nov 14, 2006 - 11:02 PM) [snapback]502336[/snapback]
i have seen it done, and i dont know how reliable this is, but i know someone who added a few more grounding wires around the engine bay, from - battery terminal to engine bay, and it did make his windows go up and down faster. I DONT GUARANTEE this to work, but it may be worth a shot, at least you cant hurt anything...i dont think.
1994 GT Hatchback
1994 ST Coupe
1988 Corolla Wagon All-Trac
1999 Corvette
2008 Cobalt SS Turbo
post Nov 15, 2006 - 9:43 AM
tim86
Joined Oct 31, '03
From Orlando, Florida
i heard that this could be caused by too much stress on the alternator if you have sound equipment and electronics, which is why im in the process of trying to find a better one... lubricating the window tracks might be good though, or maybe the silicone spray... but if its a major problem, it would prob be the window motors
post Nov 15, 2006 - 1:32 PM
Alex-UKSC
Joined Jul 23, '06
From Chester - UK
i just use some grease on mine around the mech as they get dirty over time & clog up smile.gif
My Celica Is Now For Sale
post Nov 16, 2006 - 11:35 PM
tomazws
Joined Oct 30, '04
From So Cal
QUOTE(DVSBastard @ Nov 14, 2006 - 3:02 PM) [snapback]502336[/snapback]
lol i like that.. so you'll have to hold on to the "up" button, and at the same time switching on the NOS...
post Nov 20, 2006 - 7:07 PM
K-ESD
Joined May 5, '05
From New-Brunswick Canada
technicaly speaking you could hook nos up to your power windows, just get some pneumatic cylinders and hook them up to a 2 way valve (up and down) and then to your nos bottle. pssshhhhh !!!!
your windows would be so FAST !! it'd be like, window ! - no window.... window ! - no window.....
(i'm a tard)
----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy
post Nov 20, 2006 - 7:23 PM
WH95TE
Joined Jun 16, '06
From Plantation, FL
QUOTE(K-ESD @ Nov 20, 2006 - 7:07 PM) [snapback]504072[/snapback]
post Nov 20, 2006 - 7:37 PM
uberschall
Joined Jul 29, '03
From north of detroit
i work for a company that builds window regulators for auto manufacturers, so i know a little about them. tongue.gif
the best suggestion i have is to check how much juice you're getting at the terminals. you'll have to do a little bit of disassembly. i would do this while the car is running and your typical load is present (i see you have amps...if they're usually on, they draw quite a bit of current) most motors are designed to operate reliably at around 14v, and they'll obviously run slower the less they get.
if you're not getting sufficient voltage there, i'd recommend that you turn things off/unplug them and see what helps.
it's a pain to dismount the track and motor assembly in our cars, so lubricating it will be pretty low on the list solely from an effort standpoint. you'd have to remove the regulator completely to lube it effectively.
hope that helps a little!
do you know who i am, mr. worley?
post Nov 21, 2006 - 8:14 PM
tomazws
Joined Oct 30, '04
From So Cal
I've notice something that if you push the windows up on both left + right side, the windows will go up a lot slower than just pushing up one side...
post Nov 21, 2006 - 9:03 PM
94celicadude
Joined Mar 28, '04
From St.Louis
QUOTE(tomazws @ Nov 22, 2006 - 1:14 AM) [snapback]504377[/snapback]
draws more current because it running tow motors instead of just one, so it has to slipt the amount of current available to feed two motors, and if you do both windows at night with headlights on, you can also notice the lights dimming slightly until you let got of the buttons, same reason, just drawing more current from the system.
1994 GT Hatchback
1994 ST Coupe
1999 Corvette
post Nov 23, 2006 - 9:16 PM
DVSBastard
Joined Jun 8, '04
Thanks for all the ideas / suggestions. I may give a few of these a go (will test the current, try to lube tracks, etc) and let ya'll know how it goes!
P.S. I am still looking for a small enough NOS kit to fit behind the trim! tongue.gif
post Nov 29, 2006 - 5:30 AM
Hanyo
Joined Aug 16, '03
From Bay area
i know another reason for the slower windows. The reason is the trim itself at the base of the window hardening over time. Once this trim has lost its flexiblitly it will drag on the window and give the motors more work. What you can do is replace the trim. I dont know the part number or the cost.
Lo-Fi Version Time is now: August 29th, 2026 - 9:50 PM
