> a/f guage, sorry aboot this
post Jul 3, 2003 - 3:31 AM
afroman
Joined Feb 9, '03
From Sioux falls, South Dakota
i bought and tried to install the autometer a/f guage i got it wired in and if it is not connected to o2 sensor then the far right green led is on if it is connected then the far left red led is on when i am hard on the gas the far left led gets brighter i can not get it to work properly. if i turn on my blinker the far left red led flashes with the blinker also when i do this my volts guage bounces with the blinker i would be so greatful for any help u could give me
i have read the other posts aboot this topic and still can not figure it out the only thing i can figure is that i have the wrong wire coming off the o2 sensor i have spliced into both and neither work
This post has been edited by afroman: Jul 3, 2003 - 3:33 AM
post Jul 3, 2003 - 5:11 AM
edo17982
Joined Dec 21, '02
From Italy
so, if u connected it between the sensor and the connector, the wire you have to splice is the BLUE one. if you've done it after the connector the wire you've to splice is the white one wink.gif
This post has been edited by edo17982: Jul 3, 2003 - 5:14 AM
post Jul 3, 2003 - 3:44 PM
afroman
Joined Feb 9, '03
i got it to work i figured it out the tap i was using was a little to big and now it works great i was wondering if anyone elses takes awhile to start working its like it needs time to warm up this is correct right? other than that it is so tight
Lo-Fi Version Time is now: September 14th, 2026 - 6:08 AM
