> 3S-GTE Fuel cut, Relaying a story
post Dec 14, 2006 - 10:43 PM
YES I KNOW THIS ISNT A CELICA! but its the same engine/pcm.
so my friend installed a bigger DP (3") and is running it open till he can get the exhaust on. is this fuel cut he's experiencing normal? i didnt know it wouldnt allow ANY boost till the next key cyle!
I'm pretty sure I hit the fuel cut on my way home from Russ' house tonight. I down shifted and floored it, and about 2 seconds after hitting full boost the car fell on its face and the SES light came on. The car stayed running, and the light went off, but anytime I hit boost at all after that, anything in the postives, the car would cut and the SES light would come on for a second or two.
So either the car wont let you boost after you hit the fuel cut, or something else is wrong. But I definitely need to get the exhaust fixed if this is going to be a common problem, lol.
I hooked up the boost gauge today to see what kind of boost I was hitting. I had to ghetto rig it, which was pretty amusing. I had the vacuum line coming out of the side air intake vent and in through the window of the car :lol:
Anyway, it's boosting up to 13psi, but not any higher than that. I'm kind of relieved because I started to think that maybe there could be a problem with the wastegate. I had to manipulate it some when I installed it.
Like I said before, once I hit the fuel cut it wont let me boost to even 1 psi before it cuts out again. All I have to do is turn the car off, then back on again and it resets it, but still a problem nonetheless.
So, first thing is to get the exhaust fixed. After that, we will see where it goes.
This post has been edited by Bitter: Dec 14, 2006 - 10:43 PM
post Dec 15, 2006 - 12:13 AM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
no reason for it to stop like that without major mods...
i still rule it as fuel cut, and the boost gauge he's using is getting a bad reading or ber-roke!
post Dec 15, 2006 - 12:19 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
Fuel cut
I will return one day.
post Dec 15, 2006 - 12:54 AM
well i know its fuel cut and so does he, is it normal for it to, after the 1st fuel cut, not allow ANY boost without hitting FC until the next key cycle?
such as...
boosting, hit 12, fuel cut, back off, reboost, hit 1psi, fuel cut. till the car is turned off and back on.
is THAT normal is what i'm trying to ask for him. i know a little about the 3sgte, but i'm not familiar with the deep specifics.
post Dec 15, 2006 - 1:22 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
yes its normal, its a safety feature from toyota. The ecu will not allow boost after fuel cut. You have to shut off the car to reset it.
post Dec 15, 2006 - 1:31 AM
thanks! he wasnt sure if thats normal (his 1st toyota) and i wasnt able to answer him well when he asked me if it was normal. i'll let him know all is well.
he's not new to boost, just new to toyotas. he's pretty well know in the mitsubishi and eclipse circles, even had his boosted eclipse GT in one of the magazines.
post Dec 15, 2006 - 1:32 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
Glad I could help. Tell him good luck with the duece.
post Dec 15, 2006 - 9:41 AM
Consynx
Joined Dec 25, '02
lol, my car doesn't do that. . .
when i hit fuel cut it sputters...
then if i get back on it it'll just go up to fuel cut again.
if i don't let off right as it sputters, it continues to try and boost, and
somehow goes like this throughout the process:
0-1-2-3-4-5-6-7-8-9-10-10-10-10-11-12-13-14-cut(0?)-(number b/t 15 and 24)
it's damn crazy, and the only reason i know it got this high was the hold feature on the boost gauge.
post Dec 15, 2006 - 2:28 PM
its fuel cut, like everyone said.
tell you friend to install a fuel cut defender, or simply disconnect and cap the vac line that goes to the map sensor (just keep an eye on your boost gauge).
post Dec 15, 2006 - 3:08 PM
Negative
Joined Apr 28, '04
From Houston, Texas
QUOTE(lagos @ Dec 15, 2006 - 7:28 PM) [snapback]510773[/snapback]
x2 Pretty much what all the 2's around here do. A golf tee and a zip tie to hold it in place works wonders for capping the vac line.
post Dec 15, 2006 - 7:21 PM
QUOTE(lagos @ Dec 15, 2006 - 2:28 PM) [snapback]510773[/snapback]
he's going to get the rest of his exhaust on (its still going to creep) and then go from there. its the stock ct26 on the car. the one original to it seized and snapped off the exhaust side! so he got a rebuilt one and put it on with the downpipe since it was all apart.
heres the original thread on the mitsu forum guys.
http://mitsuoafl.com/board/showthread.php?t=9299
post Dec 15, 2006 - 10:00 PM
lazzyboy121
Joined Feb 17, '04
From michigan
bigger injectors and proper tunning to eliminate it......
94 celica GT
92 honda prelude si<h22 swap>
93 eagle talon TSI <4G63 powered>i wish it was AWD
90 mitsu eclipse GSX<4G63 powered>SOLD
LEXUS IS300< im looking for one!
post Dec 16, 2006 - 12:03 PM
ya, he'll get around to that. probably after the holidays.
Lo-Fi Version Time is now: August 25th, 2026 - 12:12 AM
