Dec 24, 2006 - 12:26 AM
Enthusiast ![]() ![]() Joined Sep 29, '05 From Rochester, Massachusetts Currently Offline Reputation: 2 (100%) |
ok so i have oil on my sparks and a pretty good oil leak from my engine, i cant seem to locate it because there is too much fluid...
i also have a misfire in cylinders 1 and 4 blue smoke out the exaust on startup also i was thinking headgasket, oooor piston rings? what do u think? -------------------- ![]() The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed? |
Dec 24, 2006 - 12:53 AM
Enthusiast ![]() ![]() ![]() Joined Mar 4, '06 From Ohio Currently Offline Reputation: 10 (100%) |
Blue smoke on a cold start is valve seals. Its not as big a deal as rings would be. Start there and while your in there replace seals behind the timing cover, valve cover seals and distributor o-ring.
Dec 24, 2006 - 12:58 AM
sounds like bad plug tube seals and worn valve seals.
Dec 24, 2006 - 1:01 AM
so how involved is that replacement ^
Dec 24, 2006 - 1:20 AM
Enthusiast ![]() ![]() Joined Nov 4, '03 From Vancouver, Canada! Currently Offline Reputation: 0 (0%) |
I had the same problem.... replaced the plug tube seals and the main valve cover seal.... still leaks into tube #1
maybe its just old oil since it is impossible to clean out |
Dec 24, 2006 - 1:51 AM
Enthusiast ![]() ![]() Joined Sep 1, '06 From Michigan Currently Offline Reputation: 0 (0%) |
every once in a while i have blue smoke come from my car, but thats only in the morning like the first start of the day. every other cold start is fine. And I also have this ticking noise which i beleive to be a lifter noise am i correct?
This post has been edited by n1ckz0r: Dec 24, 2006 - 1:53 AM -------------------- ![]() |
Dec 26, 2006 - 4:51 PM
Enthusiast ![]() Joined Nov 29, '06 From Newnan, Ga. Currently Offline Reputation: 3 (100%) |
I just replaced mine and it took about 8hrs of work, special tooling, I turn wrenches for a living so it may take a little longer, I spent $37 for the seals, $15 for a valve seal pliers, $55 for a on the car valve spring compressor.
Dec 27, 2006 - 11:36 PM
ok so valve seals and plug tube seals.... got it. set out first thing in the morning to gather parts. -------------------- ![]() The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed? |
| Lo-Fi Version | Time is now: May 24th, 2026 - 6:07 PM |
