> Custom Hood?, Get one made?
post Jul 8, 2003 - 12:52 PM
Pvc99gT
Joined Sep 16, '02
From Somewhere around Chi-Town
anyone know of a place that will do this? i been callin around all day and no one will make a hood for a celica! might end up just gettin a CF hood. but i would really like a custom hood.
post Jul 8, 2003 - 1:14 PM
kuya1284
Joined Nov 15, '02
From Corona & Vallejo, CA
QUOTE (Pvc99gT @ Jul 8, 2003 - 10:06 AM)
Just buy some vents and ask a body shop to install it.
post Jul 8, 2003 - 3:37 PM
Seth6Gen
Joined Sep 22, '02
From Mammoth CA
buy a hood scoop from erebuni or somwhere. Then have it painted and installed... custom like woah
www.erebunicorp.com check em out
post Jul 8, 2003 - 5:17 PM
kuya1284
Joined Nov 15, '02
QUOTE (Seth6Gen @ Jul 8, 2003 - 12:51 PM)
post Jul 8, 2003 - 6:12 PM
Inferno
Joined Jan 30, '03
From Virginia
Yep, Ray. But Seth included pictures tongue.gif .
post Jul 8, 2003 - 6:18 PM
Mr7AFE
Joined Jan 28, '03
From underground
of course you could get a trd hood
post Jul 8, 2003 - 6:30 PM
kuya1284
Joined Nov 15, '02
QUOTE (Inferno @ Jul 8, 2003 - 3:26 PM)
post Jul 8, 2003 - 6:53 PM
Pvc99gT
Joined Sep 16, '02
thats what i want to do, but here is my dilemma. i know exactly how i want it and everything, but my buddy at the body shop is telling me not to do it. he says since it is different material bonded to each other, the fiberglass and metal of my hood, that even if it is put on perfectly he says the fiberglass will go all weird and warp or somethin and make the paint crack after a few months. he says he will do it if i really want him to, but he is advising against it. a guess part of the back story is that his bro did the same thing, got a scoop and molded it on, and since it was on his own car of course he was doin it perfect, and after like 7 months the paint hadnt cracked but you could see where it was going to crack. he had that on a chevy blazer, and dropped it 5.5" he says that is the reason it went to ****(suspension bein all bouncy and not cool), but his bro is the master and thinks it will get screwed up. so he told me if i dont want any problems that i should just see if i can get a custom hood made or get a CF hood. does anyone know why the fiberglass would go crazy like that or what??? i really really want the hood to be like totally custom, but if hes right it would really suck and i would have to get a CF hood later on and the vents would be wasted. with the vents im lookin at, that would be like $220 wasted, plus ruining my stock hood. can anyone explain to me what happened with the blazer hood and why it would or wouldnt happen on a celica hood. its a daily driver, he said it would be fine if it was just a show car, but not on a daily driver. kuya, i know you have experience with this kinda stuff, can you or anyone else give me a definitive answer on this? i like in chicago, if the weather would have anything to do with it. we go from super hot to super cold, if that would screw up the fiberglass enough. i just need to know ASAP cuz i gotta order this stuff or not order this stuff. and if this makes any difference, im lookin at an erbuni scoop (Celica WRC) and some M-roadster vents for the hood (any difference in the quality of extreme dimensions and team prototype? im guessing no, but there is a price difference, so i might as well ask)
post Jul 8, 2003 - 7:09 PM
kuya1284
Joined Nov 15, '02
QUOTE (Pvc99gT @ Jul 8, 2003 - 4:07 PM)
OK... your friend is right in terms of it cracking, BUT this is if it isn't installed using the correct material. You CAN NOT just use bondo. There's a different type of bondo that needs to be used. Unfortunately, I don't remember the name.
As for the quality of the parts from the different shops, they're all pretty much the same bro.
post Jul 8, 2003 - 7:30 PM
Pvc99gT
Joined Sep 16, '02
alrite, thanks kuya, i'll talk to him about the material, whatever it is he can find out and get it, no doubt about that. so if correct materials are used and the car is not lowered, ill be good? thanks again kuya!
post Jul 8, 2003 - 8:42 PM
kuya1284
Joined Nov 15, '02
QUOTE (Pvc99gT @ Jul 8, 2003 - 4:44 PM)
Lowering your won't affect the hood in any way.
post Jul 8, 2003 - 9:35 PM
SiKBOY
Joined Nov 4, '02
From Sydney, Australia
If the car is super bouncy, over time, the part where you cut the hole and bonded it up will be suseptible to failure because everytime the car bounces, its flexing the hood a little bit and where you cut the hole is the weakest part of the hood. I've heard that Bondo will have sinkback over time as well, so you might be able to tell where you cut the hole if you look closely.
post Jul 8, 2003 - 9:44 PM
Pvc99gT
Joined Sep 16, '02
well lowering it correctly wont, but doing just like coilovers, and not puttin in any other better suspension components, doenst that make the ride rather unsmooth... making it more jumpy, putting the hood and the rest of the body under more stress? makes sense to me, but i might be wrong.
post Jul 9, 2003 - 12:36 AM
kuya1284
Joined Nov 15, '02
I had a custom hood, which I sold to Jared in Ohio. My car was lowered (custom 1.55" front, H&R 1.3" rear) with stock shocks. My hood wasn't affected in any way.
The hood wouldn't flex due to bouncing. A (lightweight) hood COULD flex at high speeds (which is why some hoods were designed to use a hood spoiler).
But yeah, I never had problems with my hood due to the suspension while I had it.
-Ray
post Jul 9, 2003 - 1:27 PM
Why arent people using fiberglass when molding fiberglass scoops, thats what im doing.
post Jul 9, 2003 - 1:45 PM
kuya1284
Joined Nov 15, '02
QUOTE (Supersprynt @ Jul 9, 2003 - 10:41 AM)
You can't just use fiberglass... the heat from the engine will cause it to eventually crack...
post Jul 9, 2003 - 4:45 PM
Inferno
Joined Jan 30, '03
From Virginia
Dude, you know everything. How did you pick up so much experience?
post Jul 9, 2003 - 5:43 PM
kuya1284
Joined Nov 15, '02
QUOTE (Inferno @ Jul 9, 2003 - 1:59 PM)
Have you seen the movie Phenomenon with John Travolta? Well... something like that sorta happened to me...
post Jul 9, 2003 - 6:27 PM
Inferno
Joined Jan 30, '03
From Virginia
Please, strike me too!
post Jul 9, 2003 - 7:21 PM
kuya1284
Joined Nov 15, '02
QUOTE (Inferno @ Jul 9, 2003 - 3:41 PM)
Lo-Fi Version Time is now: June 12th, 2026 - 8:17 AM
