Jan 2, 2007 - 7:27 PM
Ok.. I should know better than to ask, but i couldnt find a def awsner. so..
Are the Gt and St front calipers the same? I have gt calipers, And I need to replace one of my front ones on my ct celica. Thanks for the help Doug |
Jan 2, 2007 - 7:37 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 11, '06 From Sefner, FL Currently Offline Reputation: 24 (100%) |
i dont know for sure but if you have a GT, stick with GT parts, why take the chance of downgrading if their not the same
Jan 2, 2007 - 7:41 PM
QUOTE(illneversellmycelli @ Jan 2, 2007 - 7:37 PM) [snapback]514687[/snapback] i dont know for sure but if you have a GT, stick with GT parts, why take the chance of downgrading if their not the same Oh my bad, I drive an ST, but have a gt parts car I could just swap over everything but im not sure if i want to do all that.. or how much work it would be |
Jan 2, 2007 - 7:49 PM
well the gt has the bigger engine so it would make sense to have bigger brakes, someone is bound to know for sure on here
Jan 2, 2007 - 8:14 PM
GT and ST front brakes are different. You would need the GT calipers, rotors and pads and they will bolt up to the ST hub perfectly. The ST lines will work just fine with the GT fronts.
Jan 5, 2007 - 12:22 PM
Enthusiast ![]() Joined Nov 10, '06 From Cleveland Currently Offline Reputation: 0 (0%) |
I got gt calipers once by mistake and they did not fit. The holes for the mounting screws were not in the same location.
Jan 5, 2007 - 12:45 PM
Enthusiast ![]() ![]() ![]() Joined May 6, '04 From antioch CA Currently Offline Reputation: 0 (0%) |
QUOTE(Batman722 @ Jan 3, 2007 - 1:14 AM) [snapback]514695[/snapback] GT and ST front brakes are different. You would need the GT calipers, rotors and pads and they will bolt up to the ST hub perfectly. The ST lines will work just fine with the GT fronts. You need the caliper bracket also the Gt caliper wont bolt to the st bracket. |
| Lo-Fi Version | Time is now: September 19th, 2026 - 11:11 AM |
