Jan 5, 2007 - 6:02 PM
Enthusiast ![]() ![]() ![]() Joined Dec 11, '06 From New Jersey Currently Offline Reputation: 0 (0%) |
I'd like to but like 2 or 3 gagues to mount on the panel that goes up to the roof right next to the driver side door? I don't know what kind to get it, i have an autmatic celi (for now.
-------------------- "Drive Well...
...Drift Better" |
Jan 5, 2007 - 8:54 PM
I have an N/A 5sfe.. I needed 2 gauges to fill up some holes I had from my 2 air gauges..
I did Vacuum (no reason but fun to watch, easy to hook up) and Volt (great to have to check battery) ![]()
-------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Jan 5, 2007 - 9:03 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 20, '06 From Florida Currently Offline Reputation: 44 (100%) |
I have a swap so my opinion is a bit swayed... but i also have a Gt with not mods etc. If i were to get gauges for that.... i would probably get gauges that helped me monitor the vital signs a bit.. like engine temp, fuel pressure and oil pressure.. just so i would know if there were any problems with those three systems.. cooling, fuel and oil
buttttt like i said thats me thinking like a 3s driver.. voltmeter wouldn't be bad, i have one of those |
Jan 6, 2007 - 1:12 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 7, '06 From Houston, Tx Currently Offline Reputation: 17 (100%) |
QUOTE(jcbass7 @ Jan 5, 2007 - 9:03 PM) [snapback]515516[/snapback] I have a swap so my opinion is a bit swayed... but i also have a Gt with not mods etc. If i were to get gauges for that.... i would probably get gauges that helped me monitor the vital signs a bit.. like engine temp, fuel pressure and oil pressure.. just so i would know if there were any problems with those three systems.. cooling, fuel and oil buttttt like i said thats me thinking like a 3s driver.. voltmeter wouldn't be bad, i have one of those QFT! -------------------- -Alex {](O_o)[}
1993.5 Toyota Supra ....with stuff.... ....sorta broken.... 1998 Toyota Celica ....this one, too, has stuff.... ....broken....yeah...definitely broken.... |
Jan 6, 2007 - 7:38 AM
![]() Enthusiast ![]() Joined Mar 29, '06 From UK Currently Offline Reputation: 0 (0%) |
or if you are really paranoid like me you can monitor every thing...lol
Jan 6, 2007 - 8:35 AM
QUOTE(P5ycho @ Jan 6, 2007 - 7:38 AM) [snapback]515610[/snapback] or if you are really paranoid like me you can monitor every thing...lol ^ hehe, on my swap i have.. boost/vac oil pressure fuel pressure water temp voltmeter exhaust temp and wideband A/F is on its way |
Jan 6, 2007 - 1:55 PM
how hard the gaguges to hook up? i'd really like to get some.. (in a sad mood about my celi just baught a "standard single din dvd player" off ebay then took it to the shop to install it today and i got a call about a half hour later, well it seems its little big to fit so we might have to cut the dash is that ok? so i said yeah thats fine cause i spent 200 dollars on the thing, i just hope the shop does a good job and it doesn't look like crap. =[ )
...Drift Better" |
Jan 6, 2007 - 3:12 PM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Oct 13, '06 From UK Currently Offline Reputation: 6 (100%) |
i really should stop going on here
Now i want more gauges maybe oil temp, oil pressure and air/fuel ratio...... Are these easy to install? -------------------- |
Jan 6, 2007 - 3:15 PM
gauges are not too dificult to wire in, u just have to fit the sensors at apropriate places in the engine bay, then run wires through the bulkhead to the gauges,
power can be taken from behind the cigarette lighter or head unit...hen u can get as creative as you like and mount the gauges where you feel they would look best... QUOTE i really should stop going on here Now i want more gauges trust me the feeling is mutual... i m trying to control myself and not buy any more toys.. then someone will show me something i like and its back to square 1 |
Jan 6, 2007 - 7:33 PM
k, well heres the thing.. after they installed my in dash dvd, theres still a din on the top of it, its just not a full din cause the dvd player was little over sized. I really need to find somthing to put in that din. It'd make it look tons nicer. Any ideas?
...Drift Better" |
Jan 6, 2007 - 10:36 PM
QUOTE(cnelson @ Jan 7, 2007 - 12:33 AM) [snapback]515718[/snapback] k, well heres the thing.. after they installed my in dash dvd, theres still a din on the top of it, its just not a full din cause the dvd player was little over sized. I really need to find somthing to put in that din. It'd make it look tons nicer. Any ideas? do you have a pic of the space?? might help us figure out what to do -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Jan 6, 2007 - 10:40 PM
![]() Enthusiast ![]() Joined Oct 29, '03 From Gosport, Hampshire, UK Currently Offline Reputation: 0 (0%) |
I would deffo get the Oil-Temp gauge. That way you can be sure the engine's warm enough before you start driving a bit harder and giving it more revs. (next on my list)
Jan 6, 2007 - 10:49 PM
here is my set-up
Jan 7, 2007 - 12:14 AM
QUOTE(jcbass7 @ Jan 6, 2007 - 10:49 PM) [snapback]515747[/snapback] here is my set-up ![]() are those the ProSport gauges that's listed in your profile? Where can I get some? -------------------- -Alex {](O_o)[}
Jan 7, 2007 - 5:27 AM
i'll take a picture after work. Thanks for everything guys.
...Drift Better" |
Jan 7, 2007 - 6:11 AM
![]() Enthusiast ![]() ![]() Joined Jan 6, '05 From Finland, Turku Currently Offline Reputation: 0 (0%) |
QUOTE(jcbass7 @ Jan 5, 2007 - 9:03 PM) [snapback]515516[/snapback] engine temp, fuel pressure and oil pressure. And now i want these meters also. -------------------- Please visit on our teams new website. hrp-tuning.com
![]() 19in deepdishes - invader bodykit - invader cf hood - x-box - dls audio |
Jan 7, 2007 - 1:10 PM
how much do you thing a shop would charge for install?
...Drift Better" |
Jan 7, 2007 - 3:12 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 10, '06 From Mozambique, Africa Currently Offline Reputation: 8 (100%) |
QUOTE(jcbass7 @ Jan 7, 2007 - 5:49 AM) [snapback]515747[/snapback] here is my set-up ![]() That is not fair! -------------------- ![]() "Remember, amateurs built the ark and professionals built the Titanic. But revolutionaries built the Celica!"- Me |
Jan 8, 2007 - 12:48 AM
Enthusiast ![]() ![]() Joined Sep 28, '06 From Montreal, QC, Canada Currently Offline Reputation: 2 (100%) |
We gotta get Doggy working on that shifter console gauge pod. Seriously.
-------------------- One o'dem crazy Canadian freaks, eh?
Jan 8, 2007 - 2:19 PM
QUOTE(GTSOwner @ Jan 8, 2007 - 7:48 AM) [snapback]516044[/snapback] We gotta get Doggy working on that shifter console gauge pod. Seriously. Most definately! But this time, not leave out the RHD folks! -------------------- ![]() "Remember, amateurs built the ark and professionals built the Titanic. But revolutionaries built the Celica!"- Me |
| Lo-Fi Version | Time is now: May 24th, 2026 - 3:58 PM |
