Jan 10, 2007 - 3:20 AM
Enthusiast ![]() ![]() ![]() Joined Mar 29, '06 From Hull, UK Currently Offline Reputation: 0 (0%) |
If you have a reversing camera, where have you located it as I have been around and in and out with mine and I can't find a really good place that will let me see much more than if I turn around.
I have a low light camera with several infrared led's so it will work in zero light, but these obviously won't light up enough of my driveway when reversing into it. Also it has a viewing angle of about 50-60 degrees, I realise if I change the lens then I could get a greater angle from it but anyone know where I could get a replacement lens for it for not much £££'s Cheers. Dan |
Jan 10, 2007 - 3:30 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 11, '04 From Oakdale, MN Currently Offline Reputation: 3 (100%) |
I put one in my 3rd brake light but don't think that you have one since you have a hatchback. Maybe hit up ebay for some lenses, and ever think about mounting it somewhere by your license plate?
-------------------- -Brad
95 GSX: Stock motor, fp3065, corn = 10.9 @ 140 06 R6: Strappd and sprocketed = 11.0 @ 127 01 a4: daily 94 Celica: totaled - someday have another celica thats fast instead of looks cool |
Jan 10, 2007 - 3:34 AM
I do have the 3rd light, which is currently full of leds for brake and reverse.
I originally wanted it outside but then thought it would end up being a waste of time cos it would need cleaning all the time. I cannot find a good internal location so it will end up going outside, was considering putting it behind the rear number plate and move the plate when I want to use it (which would keep the camera clean) but not been able to find an easy way of moving the plate. |
Jan 10, 2007 - 4:40 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) |
Don't they have some sort of license plate rear camera mounting thing on eBay?
Jan 11, 2007 - 2:12 AM
not sure tbh mate, it is a bit bulky too 5cm deep by about 4cm diameter so it doesn't actually fit into the recess for the plate. I would need to hack some of the recess out to allow it to fit in.
If I were to put it behind the plate then I would have to mount it inside the boot (which isn't a problem cos it would be easier to put some brackets in to fasten it to then. |
Jan 11, 2007 - 1:12 PM
but then.. usually they come with built-in camera... hmmm... -------------------- |
Jan 15, 2007 - 7:22 AM
Never seen those before mate.
Look a bit naff too in my opinion. |
| Lo-Fi Version | Time is now: March 19th, 2026 - 11:39 AM |
