> IC size, will it be worth it?
post Jan 26, 2007 - 6:54 PM
quicknstyle
Joined Oct 3, '02
From HOUSTON
im planning on buying a 27x3.5x6.25 intercooler. now im planning on running about 15-16lbs of boost on my swapped celica, will this be an efficient size, and will at fit with decent accomodations?
post Jan 26, 2007 - 7:25 PM
i have a 26x6x3 and thats worked fine . the idea here is to take off your bumper...and measure everything out so that you can get the biggest cooler you can fit in there.
as far as running 15-16psi. i had to add water injection to be able to safely do that on my car.
post Jan 26, 2007 - 9:14 PM
quicknstyle
Joined Oct 3, '02
From HOUSTON
water injection on its way... your post was the only reason why i decided to get a boost controller to throw in as well
post Jan 27, 2007 - 3:35 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
m gunna push a large IC idea more than anything. i could free boost 20+ psi with no signs of knock, and this "pressure drop" thing is pretty much un noticeable and effects lag minimally.
post Jan 27, 2007 - 7:56 PM
QUOTE(x_itchy_b_x @ Jan 27, 2007 - 3:35 PM) [snapback]521855[/snapback]
your right... a huge IC is a good benefit, but i just wish you had tvsv led's or had gone to the dyno with your setup. sometimes knock can be tricky to spot just based on feel.
post Jan 27, 2007 - 8:00 PM
jcbass7
Joined Apr 20, '06
From Florida
Art, when i buy my huge IC ill let you know if i knock at high boost smile.gif
what is size you mentioned before, that you believe you could fit in the gt-four bumper?
Lo-Fi Version Time is now: August 1st, 2026 - 11:31 AM
