> HID install from group buy, lets see how they turned out
post Feb 20, 2007 - 2:03 AM
rzanology
Joined Apr 25, '05
From nyc
This is the HID kit my friends and i bought from this group buy. The kits look really clean and had that "new smell" to it smile.gif so after some beers and sht talk...we got down to work. here are the pics....
Here is a pic of the kit in the box
Pic of right ballace mounted
Right light
left ballace
left light
What sucks is....the right light was giving alot of trouble...it would not come on at all. so we swapped it with the left light and everything came on fine. next we did the ballace. the right ballace turned out to be bad...so i'll have to send it back. lucky for me....i ordered 3 kits for my friends and myself...so my friend was nice enough to let me use his ballace untill i get mine replaced from the company.
heres a pic with the HIDs installed, this is next to my friends 99 GS with factory HIDs....muuuuch brighter in the celica....
heres some more with my friends 5th gen and myself.
over all everthing went smooth...very easy kit to install....just sucks my ballace was bad frown.gif
post Feb 20, 2007 - 7:49 AM
massbrandon
Joined Mar 6, '06
From massachusetts
post Feb 20, 2007 - 10:23 AM
jason
Joined Oct 7, '06
From wyomissing pennsylvania
heres an add on, advice for ppl who didnt relocate their battery.. install the pass side first cuz its a lil tight on the drivers side
before/after on friends car (silverstar's vs 8k)
this is what we are changing, the red dotted piece is the stock bulb, purple is the stock harness
unplug harness
twist bulb counterclockwise to unlock it or whatever
remove bulb...
carefully insert new bulb in, dont force, dont scrape, & dotn touch/get any oilyness on the bulb as it will kill the bulb
carefully push bulb into slots & turn clockwise to secure
these are all the connections you have to make, one to the ballast, 2 of the lil plugs coming from the plug, one to the stock harness, for my kit this connection was the hardest, didnt wanan plug in
these 2 are for aiming the headlight, bottom one is up/down, top one is for left/right - drive on a back country road somewhere that has lines, you want the center of the pass beam to be on the white line, and the left edge of the drivers beam to be on the yellow line, aim the drivers one a little lower than the pass side, and aim the pass side a lil higher, best way to do so, a 5/16th socket will fit & work, didnt try metric, just drive around & aim till you are happy, then drive for a while n make sure noone is highbeaming you and enjoy laugh.gif
post Feb 20, 2007 - 12:28 PM
tomazws
Joined Oct 30, '04
From So Cal
that 5th gen next to ur car is sexy!!
post Feb 20, 2007 - 5:00 PM
rzanology
Joined Apr 25, '05
From nyc
QUOTE(tomazws @ Feb 20, 2007 - 12:28 PM) [snapback]528713[/snapback]
yea man...that car is a thing of beauty!
Lo-Fi Version Time is now: August 11th, 2026 - 12:11 PM
