Mar 1, 2007 - 3:29 PM
Enthusiast ![]() ![]() ![]() Joined May 5, '05 From mattoon, IL Currently Offline Reputation: 2 (100%) |
im suppose to get colder burning plugs for my nitrous kit, i went to autozone and asked for copper plugs and they didn't have any, they also said i wouldn't find any for my car? are there any other kinds other than copper that burn colder? like what about platinum? i just got some bosch platinums instead will they work? and whats with that ceramic tip on them instead of just metal?
Mar 1, 2007 - 7:48 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 9, '05 From green springs ohio Currently Offline Reputation: 1 (100%) |
QUOTE(nate95 @ Mar 1, 2007 - 3:29 PM) [snapback]531799[/snapback] im suppose to get colder burning plugs for my nitrous kit, i went to autozone and asked for copper plugs and they didn't have any, they also said i wouldn't find any for my car? are there any other kinds other than copper that burn colder? like what about platinum? i just got some bosch platinums instead will they work? and whats with that ceramic tip on them instead of just metal? those plugs are junk and if you are going to run nos then i would stay with the ngk as at least the were made for your car the bosch are a little hotter and will burn out very fast -------------------- ![]() |
Mar 1, 2007 - 7:50 PM
other than copper what would be a colder plug? iridium? or what?
Mar 2, 2007 - 4:45 AM
Enthusiast ![]() Joined Oct 17, '04 From St Louis, MO Currently Offline Reputation: 0 (0%) |
bkr7es-11 plugs...
#2387 www.clubplug.com or go to napa and give them the part number -------------------- 2005 MB C200 Kompressor- K&N, Apexi WS2 Catback, DIY Voltage stabilizer, Intrax Springs, H&R RR swaybar, VDO Boost Gauge @ 6psi, Greddy L7 plugs, +0 Rear tires
To Do: E-manage Ultimate tuned up to 12psi |
Mar 2, 2007 - 5:39 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 11, '04 From Oakdale, MN Currently Offline Reputation: 3 (100%) |
1 step colder
BKR7E 2 steps BKR8E what Dan told me when I was trying to find out the exact same thing. Just walk into Napa and give them the part number, they look at you funny at first because you aren't asking questions but they do have the plugs at Napa. -------------------- -Brad
95 GSX: Stock motor, fp3065, corn = 10.9 @ 140 06 R6: Strappd and sprocketed = 11.0 @ 127 01 a4: daily 94 Celica: totaled - someday have another celica thats fast instead of looks cool |
Mar 2, 2007 - 12:56 PM
Enthusiast ![]() ![]() ![]() Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) |
QUOTE(nate95 @ Mar 1, 2007 - 4:50 PM) [snapback]531914[/snapback] other than copper what would be a colder plug? iridium? or what? "Colder" plugs can dissapate more heat away from the electrode. In non-modified cars, this can lead to fouling and poor running with build up, but in modified cars that run higher cylinder pressures than stock (nitrous, aftermarket turbos, increased boost on stock turbo engines, etc) the plugs work correctly, don't overheat and don't foul. The stock 3s-gte should use NGK BKR6E (or BKR6ES) plugs. One step colder plugs are BKR7E. These are popular plugs in many import cars (My WRX uses the same plugs...). For high-performance, nothing beats copper (standard) plugs. All other spark plugs are designed for longer life, not higher performance. Make sure you change your plugs every 10-15k miles if you use coppers... Hope that helps... -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
Mar 2, 2007 - 1:01 PM
thanks a bunch
Mar 3, 2007 - 3:42 AM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 13, '06 From UnderTheGround403 Currently Offline Reputation: 2 (100%) |
I would change them sooner than every 15k if your on coppers. For the amount they cost, and the major role they play in your cars performance id recommend chaning them at LEAST every 10k. I would say every oil change would be ideal to change the plugs (coppers).
Also if the stores cant find "bkr7e" then ask them to find "NGK 6097". I went to 3 different stores, and talked to the parts managers at 2 of them and they couldnt find bkr7e. went back and asked for 6097, and got the right plugs. BTW incase the parts guy doesnt know, for NGK, colder is higher number (7 is colder than 6). For most other plugs higher number is hotter. Just incase they try to tell you 6 is colder than 7. |
Mar 3, 2007 - 3:02 PM
ok thanks guys, also my brother has a supercharged GTP and is looking for colder plugs to will that same part number work for his car to?
Mar 3, 2007 - 6:48 PM
no a set of champions or autolite will work good for him , i dont know the part number right now
Mar 4, 2007 - 1:22 AM
Why is he looking for colder plugs? Only go with colder if you need them. Just because his car is supercharged doesnt mean he needs it, unless he iss running more than stock boost, or upgraded something that would increase his cylinder pressure/temp
Mar 4, 2007 - 9:46 PM
ya hes going to be running more boost, hes gitting the smaller pulley for it, and new PCM and other stuff. so he needs some.
Mar 5, 2007 - 9:09 AM
go to ngk's website (ngksparplugs) and look up his car
and then find whatever plug the stock NGK plug is and add 1 to the heat range for example...stock plug is IFR6AIX-11 then the colder plug will be IFR7AIX-11 (heat range 7 rather than 6) and then go on www.clubplug.net and look for IFR7AIX-11 once you find it, add it to your cart... now go to the cart and see what the 4 digit NGK part number is for that plug Take that number and go to napa and get your plugs -------------------- 2005 MB C200 Kompressor- K&N, Apexi WS2 Catback, DIY Voltage stabilizer, Intrax Springs, H&R RR swaybar, VDO Boost Gauge @ 6psi, Greddy L7 plugs, +0 Rear tires
Mar 5, 2007 - 9:49 AM
wow, ok thanks a bunch that really helps us out!
Mar 6, 2007 - 10:02 AM
"teach a man to fish" type of deal...
Mar 7, 2007 - 12:36 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From San Juan, PR Currently Offline Reputation: 4 (100%) |
I use NGK V-Power grade 8. All the fast guys here use, also.
| Lo-Fi Version | Time is now: May 20th, 2026 - 9:11 AM |
