Mar 4, 2007 - 6:19 AM
Enthusiast ![]() ![]() Joined Jan 23, '05 From Malta Currently Offline Reputation: 2 (100%) |
Does anyone know the diffrence with the 2 tranny as in gear ratios and final drives and may be someone can point out which tranny is better, if you where to compare them to one another.
Mar 4, 2007 - 9:27 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 23, '05 Currently Offline Reputation: 4 (100%) |
S-54: 3.285, 1.960, 1.322, 1.028, 0.820 / FD: 3.944, 4.176
-3.944 diff found in JDM/UK 2nd and 3rd gen 3S-GE -4.176 diff found in MK2 MR2 NA and 6gc GT S-51: 3.538, 1.960, 1.250, 0.945, 0.731 / FD: 3.944 - found in I4 Camry E-153: 3.230, 1.913, 1.258, 0.918, 0.731 / FD: 3.933, 4.285 -3.933 diff found in V6 Camry -4.285 diff found in MK2 MR2 turbo -V6 E-153 upgraded from 2 to 3 synchros 93+ e-153 is a good deal stronger than the s-54, however it is also significantly heavier (around 70lbs if i remember correctly, dont quote me on that). -------------------- ![]() I think Bigfoot is blurry, that's the problem. It's not the photographer's fault. Bigfoot is blurry. And that's extra scary to me, because there's a large, out-of-focus monster roaming the countryside. |
Mar 4, 2007 - 10:48 AM
QUOTE(celicaST @ Mar 4, 2007 - 9:27 AM) [snapback]532687[/snapback] S-54: 3.285, 1.960, 1.322, 1.028, 0.820 / FD: 3.944, 4.176 -3.944 diff found in JDM/UK 2nd and 3rd gen 3S-GE -4.176 diff found in MK2 MR2 NA and 6gc GT S-51: 3.538, 1.960, 1.250, 0.945, 0.731 / FD: 3.944 - found in I4 Camry E-153: 3.230, 1.913, 1.258, 0.918, 0.731 / FD: 3.933, 4.285 -3.933 diff found in V6 Camry -4.285 diff found in MK2 MR2 turbo -V6 E-153 upgraded from 2 to 3 synchros 93+ e-153 is a good deal stronger than the s-54, however it is also significantly heavier (around 70lbs if i remember correctly, dont quote me on that). Excellent man, thats the info I needed, the best I have the S54 gearbox, I am going to convert it to a Race dogbox with sequential Shifter for drag racing, ohh and 6speed. but I think I will use the E153 as the primary shaft where the clutch disc gets connected is smaller on the S54 and it is easier for me to buy clutches with larger amount of toruqe that can be transmitted to the engine. What do you think? -------------------- |
| Lo-Fi Version | Time is now: September 13th, 2026 - 7:40 PM |
