Mar 9, 2007 - 5:05 PM
Enthusiast Joined Mar 9, '07 From Columbus Currently Offline Reputation: 0 (0%) |
Hi!
Where I should drill a hole under the steerin wheel to have good access to run the wire to the battery from my amp. So far i went thru the door, but i would like to go thru the firewall Thank You for replies |
Mar 9, 2007 - 6:07 PM
Mar 9, 2007 - 6:17 PM
Enthusiast ![]() ![]() ![]() Joined Feb 16, '06 From Maui, Hawaii Currently Offline Reputation: 6 (100%) |
I should of done mine the way K-ESD did
Mar 9, 2007 - 9:51 PM
thank you guys! that's helped alot
Mar 9, 2007 - 10:52 PM
Enthusiast ![]() ![]() ![]() Joined Dec 11, '06 From New Jersey Currently Offline Reputation: 0 (0%) |
i thought there was a gromit where you could fit wires in the firewall? right by the glove box some where?
-------------------- "Drive Well...
...Drift Better" |
Mar 10, 2007 - 12:33 AM
QUOTE(cnelson @ Mar 9, 2007 - 9:52 PM) [snapback]534888[/snapback] i thought there was a gromit where you could fit wires in the firewall? right by the glove box some where? true, except the battery is located on the other side, so it's easier to do it from that one side. -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
| Lo-Fi Version | Time is now: August 1st, 2026 - 9:06 AM |
