> Brake lines connections - thread size and pitch
post Mar 12, 2007 - 4:27 PM
valerit1
Joined May 2, '06
From Nevada
Could you guys tell me the thread size and pitch for the brake line connections -
the small ones where they meet at the junctions, for example.
Thanks!
post Mar 12, 2007 - 4:53 PM
10x1.0.
post Mar 12, 2007 - 4:57 PM
Negative
Joined Apr 28, '04
From Houston, Texas
QUOTE(Coomer @ Mar 12, 2007 - 9:53 PM) [snapback]535643[/snapback]
10x1.0.
Hey Coomer. I know it's a little late but if you still need those Swagelok or Parker P/N's I got the book not 2 feet away. I'm telling you Parker A-lok is the way to go - swage them once and forget about them.
Be glad to help.
post Mar 12, 2007 - 5:00 PM
valerit1
Joined May 2, '06
From Nevada
Thanks, but - are you sure? 1/8 npt perfectly fits there - well, not "perfectly'
but quite acceptable.
QUOTE(Coomer @ Mar 12, 2007 - 4:53 PM) [snapback]535643[/snapback]
10x1.0.
post Mar 12, 2007 - 5:03 PM
Negative
Joined Apr 28, '04
From Houston, Texas
Highly possible and 1/8npt is a tapered thread so as long as you use pipe dope or teflon tape and be sure the fit is at least close you should have no leaks. Remember that brake lines are fairly high pressure and very important. You don't want to loose pressure at the wrong time.
post Mar 13, 2007 - 12:23 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
it's probably not npt. i would guess to be bspt very similar i think it's one thread off.
post Mar 13, 2007 - 12:54 PM
QUOTE(Negative @ Mar 12, 2007 - 1:57 PM) [snapback]535646[/snapback]
Be glad to help.
That's alright man...I'm just going to re-use some of the factory fittings. smile.gif
And I'm almost positive that they're 10x1.0.
post Mar 14, 2007 - 8:58 AM
Negative
Joined Apr 28, '04
From Houston, Texas
QUOTE(rjbibeau @ Mar 13, 2007 - 5:23 PM) [snapback]535894[/snapback]
Actually same thread pitch but straight thread - not tapered. That's why NPT will work even though it's not the right one.
Lo-Fi Version Time is now: June 12th, 2026 - 6:17 AM
